Need to try another Voltage Regulator, Modesto area, Anyone have an extra? |
oakdalecurtis |
Jul 26 2016, 02:40 PM
Oakdalecurtis Group: Members Posts: 1,323 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
I need to try a different voltage regulator and I live in the Modesto area. I'm driving a '76 with the 2.0 engine, Optima Red battery. I just installed a new alternator, and it's putting out 18 volts to the battery, not good! When I installed the new alternator, I also put in a new Beru 024 VR, so I want to try another VR and see if the Beru is the problem. Anyone in the area have an extra one by chance?
Also, I have read that the Optima batteries need a little higher charging voltage. Does anyone recommend an adjustable VR like the one sold at DaveBarton.com for my application, and what voltage should I set it for if I get one? thanks |
Drums66 |
Jul 26 2016, 03:25 PM
...People in the Know say,replace them together.....Alternator/Voltage regulator
and you should try the solid state of your choice; I like and use Borg/Warner. :i (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/bye1.gif) |
Lo-Fi Version | Time is now: 23rd April 2024 - 11:35 AM |
