Weights, Various transmissions and motor |
Randal |
Jul 26 2016, 04:33 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Looking for the weights of a 915 and G50 transmissions. Also need the weight of a 993 (air cooled) 3.6-liter motor.
Much thanks. |
914forme |
Jul 26 2016, 05:46 PM
I have seen numbers between 98 to 119 depending of if dry or with brakes and fluids for the 915
And between 155 lbs wet for a 5-speed G50 and 158 for the 6 speed, but that was dry weight. |
Randal |
Jul 26 2016, 10:11 PM
I have seen numbers between 98 to 119 depending of if dry or with brakes and fluids for the 915 And between 155 lbs wet for a 5-speed G50 and 158 for the 6 speed, but that was dry weight. Perfect. Now I just need the 993 engine weight. (IMG:style_emoticons/default/dry.gif) |
914forme |
Jul 27 2016, 04:19 AM
0396 |
Jul 27 2016, 08:57 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
I believe that the 993 engine came out in 96 not 87. In 87, to my knowledge it was still 3.2. Some folks get the 964 3.6 mixed up with the 96 Vram 3.6 . The last generation of air cooled was the 3.6 vram ( 96 -98) Correct me if I'm wrong...if I had to take a guess, I would say 450 lbs dry. The additional weights came via all those extra components on the top of engine and the large vram. Best is to post your question on the Bird site. |
jd74914 |
Jul 27 2016, 09:13 AM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I think he mis-typed and meant 1997. (IMG:style_emoticons/default/smile.gif)
This is copied from an old post on Pelican (993 variants at bottom of list): kg lbs-- models-- Source 182 400 2.4L E, S, RS 1972-73 Tech. Spec. book 183 403 2.4L T 1972-73 Tech. Spec. book 200 440 2.7L 1975-1977 Aichle - 911 Engines 190 419 78-83 930/09,19,10 78-81 78-81 & 82-83 Tech Spec. book 200 441 78-83 930/03-08,13-17 78-81 & 82-83 Tech Spec. book 190 462 3.0L 1980-82 Aichle - 911 Engines 219 483 84-87 930/20,26 84-87 Tech Spec. book 220 485 84-87 930/21,25 84-87 Tech Spec. book 219 482 3.2L 1987 - 1988 Aichle - 911 Engines 238 524 964 89-94 M64/01,02 ROW &US 964 Tech Spec. book 226 497 M64/03 RS 964 Tech Spec. book 275 605 M30/69 3.3L 964 Tech Spec. book 276 608 M64/50 3.6L 964 Tech Spec. book 232 510 M64/05-08 993 Tech Spec. book 221 487 M64/20 993RS v-ram w/o ZMS 993 Tech Spec. book 230 507 M64/20 993RS v-ram w/ ZMS 993 Tech Spec. book |
whitetwinturbo |
Jul 27 2016, 10:49 AM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
G50 from 930/turbo is a 4 speed.......... (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif)
SirAndy |
Jul 27 2016, 11:00 AM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
914forme |
Jul 27 2016, 11:30 AM
Yep I am down a couple of typing fingers on my right hand, quite easy for me to mis type stuff. And hell I mistyped stuff even when I had use of those 2 fingers (IMG:style_emoticons/default/dry.gif) |
Randal |
Jul 27 2016, 12:21 PM
What do you think it is Andy? |
SirAndy |
Jul 27 2016, 01:40 PM
What do you think it is Andy? No idea. I remember Mark and i lifting it fairly easily ... (IMG:style_emoticons/default/idea.gif) |
jd74914 |
Jul 27 2016, 02:33 PM
What do you think it is Andy? No idea. I remember Mark and i lifting it fairly easily ... (IMG:style_emoticons/default/idea.gif) Was that fully dressed? I think these weights are fully dressed and in my experience its the ancillaries which really add up. |
SirAndy |
Jul 27 2016, 03:01 PM
Was that fully dressed? I think these weights are fully dressed and in my experience its the ancillaries which really add up. Picture from the day we were schlepping it around the shop ... (IMG:http://www.914world.com/bbs2/uploads/post-179-1181192469.jpg) |
Randal |
Jul 27 2016, 04:46 PM
What do you think it is Andy? No idea. I remember Mark and i lifting it fairly easily ... (IMG:style_emoticons/default/idea.gif) Right, easy for two weight lifters! |
Lo-Fi Version | Time is now: 28th April 2024 - 06:08 AM |
