Rear brake disk retaining screws for drilled 5 lug hubs |
tornik550 |
Jul 26 2016, 05:10 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
On the rear of my 914, I have 4 lug hubs drilled to 5 lugs. I have sebro rear disks.
I was going to install them however when the hubs were drilled, now the M6 disk retaining screws do not line up. Are these necessary? Should I just drill and tap the holes for the retaining screws? |
ConeDodger |
Jul 26 2016, 05:43 PM
Apex killer! Group: Members Posts: 23,583 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I think, you have to drill and tap a new hole. Which reminds me, I didn't. So apparently you can get away without doing it. The lug nuts hold everything???
wndsrfr |
Jul 26 2016, 05:47 PM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
I think, you have to drill and tap a new hole. Which reminds me, I didn't. So apparently you can get away without doing it. The lug nuts hold everything??? Been running mine without the screws for about 5000 miles of DE's on track over 3 years with zero issues. The lug nuts do the actual clamping of the rotor to the hub. I could possibly see that the little screws might help with centering, but sure haven't noticed any problems. Always, always, always properly torque your lugs....96ft.lb. |
Lo-Fi Version | Time is now: 12th May 2024 - 02:26 PM |
