Rear brake disk retaining screws for drilled 5 lug hubs |
tornik550 |
Jul 26 2016, 05:10 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
On the rear of my 914, I have 4 lug hubs drilled to 5 lugs. I have sebro rear disks.
I was going to install them however when the hubs were drilled, now the M6 disk retaining screws do not line up. Are these necessary? Should I just drill and tap the holes for the retaining screws? |
Spoke |
Jul 27 2016, 07:47 AM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
The securing holes on 911 rotors do not match up with the securing threads on the 914-4 hubs. if you want to use the screws, you'll have to drill and tap the hub for the 911 rotor securing screw holes.
I did this by mounting the rotor holding on with a couple of lugs, and by using the same size drill bit as the diameter of the securing screw holes in the rotor, drill just enough to get an idea of where the center of the mounting holes go. Then remove the rotor and drill the holes out with the proper sized drill for the tap. Tap the holes and you're done. |
Lo-Fi Version | Time is now: 13th May 2024 - 08:33 AM |
