1972/73 1.7 deceleration valve? and a couple other Qs, need to know if im supposed to have one! |
Lowsquire |
Jul 27 2016, 08:54 AM
Newbie Group: Members Posts: 20 Joined: 23-April 16 From: Austin Texas Member No.: 19,926 Region Association: Southwest Region |
hey all,
I've got a 10/72 build 1.7 and it came with all the FI components in a box, seemingly rebuilt..Im currently working out where the hell it all goes and what connects to what. Some diagrams Ive found show a decel air bypass valve and some dont. Does anybody know for sure if a late 72 (titled as 73 ) car would have one? its the only thing not included in the box of bits. another question..air filter. Its the round plastic housing. Has anyone worked out which commonly available (wix,K&N etc..) air filter fits nicely in these? part no. would be great. Thank in advance. (I don't post much as I've found the answer to nearly every question I've had so far in the archives of this site.. very handy!) Just recieved a huge box of seals from 914rubber.com, so off to the garage to fit it all up! (IMG:style_emoticons/default/idea.gif) |
era vulgaris |
Jul 27 2016, 10:22 AM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
72 should have a decel valve. My old 72 did. I think only 70-71 did not.
Your air cleaner is an oil bath air cleaner. It doesn't use a paper filter. Open it up and put any weight oil in it up to the fill line. Edit...I just saw you said your car is titled as 73. Model year is determined by VIN, not build date. If your VIN starts with 473...you have a 73. I think 73's might have had a paper filter in the air cleaner. I'm not sure when they switched. Someone else can verify. |
BillC |
Jul 27 2016, 12:16 PM
Senior Member Group: Members Posts: 536 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
72 should have a decel valve. My old 72 did. I think only 70-71 did not. Your air cleaner is an oil bath air cleaner. It doesn't use a paper filter. Open it up and put any weight oil in it up to the fill line. Edit...I just saw you said your car is titled as 73. Model year is determined by VIN, not build date. If your VIN starts with 473...you have a 73. I think 73's might have had a paper filter in the air cleaner. I'm not sure when they switched. Someone else can verify. '73 1.7's do have a paper filter. Unfortunately, the filter is no longer available. There's a NAPA filter that is close (there's a thread on this forum about it), but you need to make an adapter plate for the bottom to make it fit -- the filter is the right height and right O.D., but has a larger I.D and won't seal on the bottom of the filter housing without an adapter plate. |
Lowsquire |
Jul 27 2016, 12:42 PM
Thanks for that!
okay so ill hunt down a Decel valve and have a look for that thread about airfilters. mine is a paper element. Vin starts 473 so its a '73. build date oct72. appreciate the help. |
Lo-Fi Version | Time is now: 3rd May 2024 - 01:37 AM |
