Newbie question 1: Dashboard |
amfab |
Jul 28 2016, 02:23 PM
Member Group: Members Posts: 391 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None |
Hi I am new to this forum. Thanks in advance for the help.
Car is a 1974 2.0. I am replacing the radio and have a roll of basket weave vinyl to do the rest of the dash as well. My Question is: was the radio plate always separate in terms of vinyl basket weave or did the vinyl ever come as one contiguous piece from the drivers side all the way to the seam at the glove box with no seam for the radio plate, or were the radio plates always separate? -Andrew |
Jul 28 2016, 02:58 PM
Custom Member Group: Members Posts: 24,501 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Seperate, but I suspect if you tack weld in the plate, it will work.
amfab |
Jul 28 2016, 06:13 PM
Oh, I meant the vinyl, not the metal. I was thinking of just taking the vinyl right across the seam without cutting it. If none never came like that Im fine with the seam. Probably easier to serve or replace the radio
anderssj |
Jul 28 2016, 08:10 PM
Dog is my copilot... Group: Members Posts: 1,641 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
Oh, I meant the vinyl, not the metal. I was thinking of just taking the vinyl right across the seam without cutting it. If none never came like that Im fine with the seam. Probably easier to serve or replace the radio As far as I know, they all had black vinyl that ended at the left edge of the plastic radio face plate (also a black basket-weave look). The right side of that plastic radio face plate was bordered by the left edge of the glove box door as shown a friend's car: When I re-did my dash I used a replacement metal radio mounting plate (from RennenMetal I think), then covered the entire dash face with what looks like a single piece of tan basket-weave across the dash from the driver's side vent to the left edge of the glove box: The overlap under the heater/fan control is hidden when the lower dash is in place. When everything is installed, it looks like a seamless piece of vinyl. Of course, I couldn't find a picture of that (IMG:style_emoticons/default/headbang.gif) Hope this helps! |
amfab |
Jul 28 2016, 08:41 PM
yes, thanks Steve, that is what I was thinking, running the vinyl all the way across. I will set up my radio first in the plate and decide—if I can get it in and out from behind I think I may run it all the way across. r_towle's idea of welding it is a good idea to keep it stable. Now I have to decide how motivated I am.
Thanks again -Andrew |
Larmo63 |
Jul 28 2016, 09:22 PM
You could even run a piece of thin foam core under it too.
Real thin…... |
PancakePorsche |
Jul 29 2016, 02:11 AM
Member Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None |
FWIW, my 1976 had single continuous piece of brick weave from factory.
914Next |
Jul 29 2016, 02:40 AM
Senior Member Group: Members Posts: 698 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest |
My understanding is that all radios were dealer installed such that none were really "factory". As a result, I think you would likely see many variations. One example is mine where they actually used plain black vinyl on the radio plate even though there is basket weave on the rest of the dash. I know this is as delivered since the car is very completely documented and i have had conversations with the original owner about this. I suspect for some reason they did not have basket weave in stock when they installed the radio...or they grabbed a radio from another Porsche as a quick solution and did not bother to change the vinyl.
Mikey914 |
Jul 29 2016, 03:12 AM
The rubber man Group: Members Posts: 12,625 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
My understanding is that all radios were dealer installed such that none were really "factory". As a result, I think you would likely see many variations. One example is mine where they actually used plain black vinyl on the radio plate even though there is basket weave on the rest of the dash. I know this is as delivered since the car is very completely documented and i have had conversations with the original owner about this. I suspect for some reason they did not have basket weave in stock when they installed the radio...or they grabbed a radio from another Porsche as a quick solution and did not bother to change the vinyl. Correct I have the delete, DIN, and OEM style plates if you need any. |
914Next |
Jul 29 2016, 03:24 AM
My understanding is that all radios were dealer installed such that none were really "factory". As a result, I think you would likely see many variations. One example is mine where they actually used plain black vinyl on the radio plate even though there is basket weave on the rest of the dash. I know this is as delivered since the car is very completely documented and i have had conversations with the original owner about this. I suspect for some reason they did not have basket weave in stock when they installed the radio...or they grabbed a radio from another Porsche as a quick solution and did not bother to change the vinyl. Correct I have the delete, DIN, and OEM style plates if you need any. Thanks. I did buy an original plate with basket weave but the car is so original that I've decided to leave it as delivered. Some of these quirky things are what makes a particular car interesting. Steve |
amfab |
Jul 29 2016, 08:35 AM
My understanding is that all radios were dealer installed such that none were really "factory". As a result, I think you would likely see many variations. One example is mine where they actually used plain black vinyl on the radio plate even though there is basket weave on the rest of the dash. I know this is as delivered since the car is very completely documented and i have had conversations with the original owner about this. I suspect for some reason they did not have basket weave in stock when they installed the radio...or they grabbed a radio from another Porsche as a quick solution and did not bother to change the vinyl. Correct I have the delete, DIN, and OEM style plates if you need any. HI MIke, My new plate and vinyl that I have ready to go in are both from you I may be new, but I do research vendors : ) |
Mikey914 |
Jul 29 2016, 09:34 AM
Thanks,
My site is a little hard to find stuff on. Mark |
amfab |
Jul 31 2016, 08:04 AM
Thanks, My site is a little hard to find stuff on. Mark Just put the search box at the top. I didn't notice it the first few times I was there. I just bought some pretty expensive super strength moulding double sided tape at the auto parts store: http://www.shop3m.com/3m-scotch-mount-mold...-in-x-5-ft.html Is that what I want use to stick the metal backing plate back in? This place is great BTW, Thanks for the help. |
Lo-Fi Version | Time is now: 28th March 2024 - 10:54 PM |
