Newbie Question 2: Weber Carburetors |
amfab |
Jul 28 2016, 02:24 PM
Member Group: Members Posts: 393 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None |
I just bought a 74 2.0. Previous owner says previous owner rebuilt it out to 2.1 a few years ago but there is no documentation. Regardless, it IS a GA with 3 bolt intakes so I will assume at least 42mm intake valves.
It came with dual Weber 36idfs with 32 venturis. The motor seems a bit anemic at the higher RPM. To me—quite an amateur at this kind of stuff—it kind of makes sense because the throttle bodies seem a bit small for the motor (it seems that a lot of the type 1 guys use 36idfs on sub-2 litre motors). I just had the car tuned up and it runs very nicely, but not a lot of power and it flattens out fast above 4kRPM I considered megasquirt, but because I have linkage and manifolds I was thinking going the easier and cheaper route of 40 or 44 idfs. After doing a bit of research, my thoughts are either 40idfs with 34 venturis or 44idfs with 36 venturis. Just a little more oomph will be able to carry me until I eventually do a six conversion in a couple years. Are 44idfs too much carb for the 2.0 (or possible 2.1)? Unfortunately, there is no documentation on the cam either. I (and my mechanic) are thinking its stock or close to it. Any advice would be greatly appreciated. Thank you -Andrew |
Lo-Fi Version | Time is now: 17th May 2024 - 09:18 PM |
