> Found a relay board!, Member sending me one, thanks!
oakdalecurtis
post Jul 28 2016, 06:40 PM
Oakdalecurtis
I think I found my charging problem. Here's a picture of the bottom of my relay board. I'm told that the big hole and melting on the edges is not normal, and the VR contact spades don't stay up. (What in the world might cause that?) Does anyone have another relay board on the shelf they aren't using?
Thanks
post Jul 28 2016, 06:52 PM
Post a WTB: in our classified forum. (IMG:style_emoticons/default/beerchug.gif)
oakdalecurtis
post Jul 28 2016, 07:03 PM
Oakdalecurtis
QUOTE(76-914 @ Jul 28 2016, 05:52 PM) *
ty, I should have known that, but never used it. Posted there now.
cwl
Tom_T
post Jul 28 2016, 08:37 PM
TMI....
QUOTE(oakdalecurtis @ Jul 28 2016, 06:03 PM) *
cwl
Curtis,
I posted in there too .... go figure, suggested you contact Jeff Bowlsby for a rebuilt one or to redo yours. They could've just sent you to him on this forum too. Jeff is near-ish to you in Pleasanton.
http://bowlsby.net/914/WiringHarnesses/
Tom
oakdalecurtis
post Jul 28 2016, 08:53 PM
Oakdalecurtis
QUOTE(Tom_T @ Jul 28 2016, 07:37 PM) *
cwl
Curtis,
Tom
Thanks Tom, I got mine working, but wlll have to see how it holds up, may be in touch with Jeff,
curtis
porschetub
post Jul 29 2016, 01:31 PM
QUOTE(oakdalecurtis @ Jul 29 2016, 12:40 PM) *
Thanks
I had a similar issue with my board,the pins for the 25amp fuse were a bit cooked and loose.
Cleaned out all the old tar cleaned all the strips,used epoxy to fix the loose areas,masked off the opening and used a spray can of liquid tape insulation called Performix (made by Plasti Dip ),had to apply about 6 layers to build and fill the area up.....happy with the result.
GeorgeRud
post Jul 30 2016, 09:56 AM
Try removing the voltage regulator off the board and plugging it directly into the rear engine harness. That should let you know if it is the board. The pins for the VR really just allow the regulator to mount on the board.
oakdalecurtis
post Jul 30 2016, 11:43 AM
Oakdalecurtis
QUOTE(GeorgeRud @ Jul 30 2016, 08:56 AM) *
Thanks George, but I'm not sure I'd plug it in the right spot and another member is sending me an almost new board with all the components on it including another VR. I'll try that and see what happens next. Appreciate your advice though.
mb911
post Jul 30 2016, 12:05 PM
This thread got me thinking is there a diy rebuild thread out there for these?
porschetub
post Jul 30 2016, 05:35 PM
QUOTE(mb911 @ Jul 31 2016, 06:05 AM) *
Not a really hard job Ben just very time consuming,the tar (pitch ) takes for ever to remove and you have to be carefull not to dislodge the contact strips,if this happens you can clear epoxy them back down.
Funny I remember my new GF ''said can I help ''and scrapped the majority of the tar out for me,she was sat down wearing a rather short dress......enough to say it didn't get finished that sunny afternoon....... (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/grouphug.gif)
mb911
post Jul 30 2016, 05:42 PM
I remember those days.. Lol
So what really needs to be rebuilt on them? Just resolder connections etc?
- Lo-Fi Version Time is now: 16th April 2024 - 05:45 AM
