Found a relay board!, Member sending me one, thanks! |
oakdalecurtis |
Jul 28 2016, 06:40 PM
Oakdalecurtis Group: Members Posts: 1,323 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
I think I found my charging problem. Here's a picture of the bottom of my relay board. I'm told that the big hole and melting on the edges is not normal, and the VR contact spades don't stay up. (What in the world might cause that?) Does anyone have another relay board on the shelf they aren't using?
Thanks |
76-914 |
Jul 28 2016, 06:52 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Post a WTB: in our classified forum. (IMG:style_emoticons/default/beerchug.gif)
oakdalecurtis |
Jul 28 2016, 07:03 PM
ty, I should have known that, but never used it. Posted there now. cwl |
Tom_T |
Jul 28 2016, 08:37 PM
ty, I should have known that, but never used it. Posted there now. cwl Curtis, I posted in there too .... go figure, suggested you contact Jeff Bowlsby for a rebuilt one or to redo yours. They could've just sent you to him on this forum too. Jeff is near-ish to you in Pleasanton. http://bowlsby.net/914/WiringHarnesses/ (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
oakdalecurtis |
Jul 28 2016, 08:53 PM
ty, I should have known that, but never used it. Posted there now. cwl Curtis, I posted in there too .... go figure, suggested you contact Jeff Bowlsby for a rebuilt one or to redo yours. They could've just sent you to him on this forum too. Jeff is near-ish to you in Pleasanton. http://bowlsby.net/914/WiringHarnesses/ (IMG:style_emoticons/default/beerchug.gif) Tom Thanks Tom, I got mine working, but wlll have to see how it holds up, may be in touch with Jeff, curtis /////// |
porschetub |
Jul 29 2016, 01:31 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I think I found my charging problem. Here's a picture of the bottom of my relay board. I'm told that the big hole and melting on the edges is not normal, and the VR contact spades don't stay up. (What in the world might cause that?) Does anyone have another relay board on the shelf they aren't using? Thanks I had a similar issue with my board,the pins for the 25amp fuse were a bit cooked and loose. Cleaned out all the old tar cleaned all the strips,used epoxy to fix the loose areas,masked off the opening and used a spray can of liquid tape insulation called Performix (made by Plasti Dip ),had to apply about 6 layers to build and fill the area up.....happy with the result. |
GeorgeRud |
Jul 30 2016, 09:56 AM
Try removing the voltage regulator off the board and plugging it directly into the rear engine harness. That should let you know if it is the board. The pins for the VR really just allow the regulator to mount on the board.
oakdalecurtis |
Jul 30 2016, 11:43 AM
Try removing the voltage regulator off the board and plugging it directly into the rear engine harness. That should let you know if it is the board. The pins for the VR really just allow the regulator to mount on the board. Thanks George, but I'm not sure I'd plug it in the right spot and another member is sending me an almost new board with all the components on it including another VR. I'll try that and see what happens next. Appreciate your advice though. |
mb911 |
Jul 30 2016, 12:05 PM
914 Guru Group: Members Posts: 6,816 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
This thread got me thinking is there a diy rebuild thread out there for these?
porschetub |
Jul 30 2016, 05:35 PM
This thread got me thinking is there a diy rebuild thread out there for these? Not a really hard job Ben just very time consuming,the tar (pitch ) takes for ever to remove and you have to be carefull not to dislodge the contact strips,if this happens you can clear epoxy them back down. Funny I remember my new GF ''said can I help ''and scrapped the majority of the tar out for me,she was sat down wearing a rather short dress......enough to say it didn't get finished that sunny afternoon....... (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/grouphug.gif) |
mb911 |
Jul 30 2016, 05:42 PM
I remember those days.. Lol
So what really needs to be rebuilt on them? Just resolder connections etc? |
Lo-Fi Version | Time is now: 29th April 2024 - 11:56 AM |
