Door Gaps |
Door Gaps |
Mike1981 |
Jul 29 2016, 01:44 PM
Member Group: Members Posts: 212 Joined: 21-July 14 From: Detroit MI Member No.: 17,663 Region Association: Southern California |
Hello
I have a 1972 914 The passengers side was hit and "repaired by P.O." I have noticed when I close the passengers door it hits the rear quarter panel, chipping the paint. On the opposite end that meets the front fender the gap is wider that the drives side gap. Is there any way to adjust the door forwards towards the front fender? Thanks |
John |
Jul 29 2016, 02:20 PM
I have "moved" the forward portion of the door opening further forward (at the location where the door bolts on).
This effectively will move the entire door forward in the opening. This car has a cage installed and I jacked the front hinge point forward carefully and all turned out well. YMMV (your mileage may vary). Typically, if the doors don't fit, it may indicate a twisted tub. My car has been well aligned and braced so that at least the suspension pickup points are and stay where they are supposed to be regardless of the rest of the bodywork. Do you have any pictures? |
Mike1981 |
Jul 29 2016, 03:15 PM
I have "moved" the forward portion of the door opening further forward (at the location where the door bolts on). This effectively will move the entire door forward in the opening. This car has a cage installed and I jacked the front hinge point forward carefully and all turned out well. YMMV (your mileage may vary). Typically, if the doors don't fit, it may indicate a twisted tub. My car has been well aligned and braced so that at least the suspension pickup points are and stay where they are supposed to be regardless of the rest of the bodywork. Do you have any pictures? Oh yes (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-17663-1469826946.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-17663-1469826946.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-17663-1469826947.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-17663-1469826947.4.jpg) |
Garland |
Jul 29 2016, 04:18 PM
Restoration Fanatic Group: Members Posts: 1,327 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
Mike,
The only way I can see to do that, is to grind the face of the hinge were it mounts to the body of the car.. This would only buy you a little bit. Maybe 1/8 " |
Jul 29 2016, 04:22 PM
Custom Member Group: Members Posts: 24,560 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
use a porta power or a bottle jack and a 2*4 to move that inner fender forward 1/8 or more....it can be done and that is the only way to fix what you got unless you want to remount the door hinges.
I would use a jack, push it in points, dont try to do it all at once, keep checking your progress. Rich |
rgalla9146 |
Jul 29 2016, 04:40 PM
Advanced Member Group: Members Posts: 4,544 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Got a sledge hammer and a 2 foot 2" x 4" ?
Open the door fully, place one end of the 2 by 4 against the 3 bolts of the upper hinge. Strike the other end of the 2 by 4 with your best shot. Repeat on lower hinge. ..... better be sure beforehand that your car isn't just sagging. Your front gap doesn't look overly large. |
dlee6204 |
Jul 29 2016, 04:51 PM
Is there evidence that the car was hit? Seems more like rust issue to me.
Your front gap looks fine and the missing rear gap is a typical sign of very poor rust repair. |
Cairo94507 |
Jul 29 2016, 04:56 PM
Michael Group: Members Posts: 9,703 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Yeah, I would look for rust too. The front fender/door gap seems pretty typical for our cars. The rear is way off. That is more than a hinge needing to be loosened and adjusted. That is someone with 914 experience applying some pressure to move that front hinge post a tiny bit forward, I think.
Garland |
Jul 29 2016, 05:22 PM
use a porta power or a bottle jack and a 2*4 to move that inner fender forward 1/8 or more....it can be done and that is the only way to fix what you got unless you want to remount the door hinges. I would use a jack, push it in points, dont try to do it all at once, keep checking your progress. Rich I like this idea. |
rick 918-S |
Jul 30 2016, 12:05 PM
Hey nice rack! -Celette Group: Members Posts: 20,409 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Causing more damage is not the solution to an accurate repair. Remove both doors and start measuring. find the damage and form a plan for the correct repair.
rgalla9146 |
Jul 30 2016, 02:40 PM
Causing more damage is not the solution to an accurate repair. Remove both doors and start measuring. find the damage and form a plan for the correct repair. OK, OK, so I spoke harshly. But didn't I make up for it by saying the front didn't look overly large ? Doesn't that mean 'look elsewhere ?' |
porschetub |
Jul 30 2016, 04:17 PM
Advanced Member Group: Members Posts: 4,696 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Could someone have shimmed the hinges too much?,reason for asking is the door appears to be evenly too far towards the striker plate.
Mike1981 |
Jul 30 2016, 05:34 PM
Thanks for all of the advice
Yes the car was hit on the passengers side but "fixed" by P.O. I like the 2x4 and bottle jack idea |
rick 918-S |
Jul 31 2016, 11:55 AM
Thanks for all of the advice Yes the car was hit on the passengers side but "fixed" by P.O. I like the 2x4 and bottle jack idea The hinge pillar is way stronger than the latch pillar. Very likely you will just end up crushing the latch pillar. Follow this link: http://www.914world.com/specs/bodydims.php You need to take Measurements. Start with "H" then "I" then "Y" If you get wonky measurements check the other side. If you find the issue post it hear and maybe I can walk you through fixing it correctly. As you work your way through the measurements You may want to remove the targa gasket and measure "F" and "X" Often when guys improperly repair a chassis they just bend the windshield frame so the door wing window seals. |
John |
Aug 3 2016, 06:53 PM
From looking at the pictures, it appears to me that your front edge door gap looks too good to have had the hinge pillar "moved" in an accident, so my previous "advice" is out the window.
In your case, I would start by looking up critical chassis dimensions for the car (they can be found by searching here or elsewhere on the web), and then comparing the factory dimensions to what you have. It looks like your door opening has closed up (car sagging in middle). Have you had your rocker panels off or looked for rust around your jacking receptacle? This is a common point for these cars to rust and begin to collapse at. Just for grins, does your door gap change (become more normal) if you were to jack the car up on the passenger side? |
rgalla9146 |
Aug 3 2016, 09:20 PM
Double
rgalla9146 |
Aug 3 2016, 09:25 PM
A surprising issue is that both the front and rear gaps appear nearly uniform from top to bottom. At least from the provided pictures.
That is not typical of a sagging chassis. Maybe the previous repair put a quarter panel too far forward. Ricks advise is the way to go. |
Mikey914 |
Aug 4 2016, 03:04 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
If you are "lucky" you may just find the rear has bondo bringing it out 1/8". Ge some pictures of the latch area and the seam along the edge.
jkb944t |
Aug 4 2016, 10:55 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
Claus Graf |
Aug 4 2016, 03:36 PM
Member Group: Members Posts: 51 Joined: 25-November 14 From: Houston, TX Member No.: 18,154 Region Association: None |
The front door gap doesn't look large enough.
Does the roof fit OK? Compare both sides of the roof. Look under the front fender to check for any distortions. Claus |
Lo-Fi Version | Time is now: 20th April 2024 - 06:15 AM |
