Door Gaps |
Door Gaps |
Mike1981 |
Jul 29 2016, 01:44 PM
Member Group: Members Posts: 212 Joined: 21-July 14 From: Detroit MI Member No.: 17,663 Region Association: Southern California |
Hello
I have a 1972 914 The passengers side was hit and "repaired by P.O." I have noticed when I close the passengers door it hits the rear quarter panel, chipping the paint. On the opposite end that meets the front fender the gap is wider that the drives side gap. Is there any way to adjust the door forwards towards the front fender? Thanks |
r_towle |
Jul 29 2016, 04:22 PM
Custom Member Group: Members Posts: 24,577 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
use a porta power or a bottle jack and a 2*4 to move that inner fender forward 1/8 or more....it can be done and that is the only way to fix what you got unless you want to remount the door hinges.
I would use a jack, push it in points, dont try to do it all at once, keep checking your progress. Rich |
Garland |
Jul 29 2016, 05:22 PM
Restoration Fanatic Group: Members Posts: 1,329 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
use a porta power or a bottle jack and a 2*4 to move that inner fender forward 1/8 or more....it can be done and that is the only way to fix what you got unless you want to remount the door hinges. I would use a jack, push it in points, dont try to do it all at once, keep checking your progress. Rich I like this idea. |
Lo-Fi Version | Time is now: 22nd May 2024 - 08:22 PM |
