Steel Gt rocker flares |
mb911 |
Aug 5 2016, 05:16 PM
914 Guru Group: Members Posts: 6,810 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
mb911 |
Aug 6 2016, 02:44 PM
A couple of questions to answer. Yes I teach welding and fabrication at a local college. I teach how to properly use cnc brake presses,planishing hammers, English wheels, slip rollers, plate rollers, standard box and pan brakes, shot bags, shrinking and stretching metals.. I have done this for 16 years. Previous I was a welder fabricator in the avaitiob world along with rotax trained to rebuild all of their aviation engine types. Rebuilt 100s of them over the years. Along with that I had my Porsche only business where I designed and built all of the m&k exhaust.. So I guess metal working and engine builds have always been part of my life..
Now to these parts to be honest they take enough time to make that it maybe to costly to retail. I am not sure though. I would say that materials are probably only about 8 dollars per corner with the steel, blending disks, filler metals and argon. That said I believe labor is going to be about 1-1 1/2 hours per corner to make. So price might get up there. Maybe a group but and have laser cuts done Would be the best way to do this? That would help drive the price down |
dakotaewing |
Aug 6 2016, 05:04 PM
Senior Member Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
A couple of questions to answer. Yes I teach welding and fabrication at a local college. I teach how to properly use cnc brake presses,planishing hammers, English wheels, slip rollers, plate rollers, standard box and pan brakes, shot bags, shrinking and stretching metals.. I have done this for 16 years. Previous I was a welder fabricator in the avaitiob world along with rotax trained to rebuild all of their aviation engine types. Rebuilt 100s of them over the years. Along with that I had my Porsche only business where I designed and built all of the m&k exhaust.. So I guess metal working and engine builds have always been part of my life.. Now to these parts to be honest they take enough time to make that it maybe to costly to retail. I am not sure though. I would say that materials are probably only about 8 dollars per corner with the steel, blending disks, filler metals and argon. That said I believe labor is going to be about 1-1 1/2 hours per corner to make. So price might get up there. Maybe a group but and have laser cuts done Would be the best way to do this? That would help drive the price down Most of the guys here that would want these will have some welding skills. You could offer the cnc'd cut parts, as one option, and welded as another. Cost difference would be the cost of your labor. Each corner would need to be labeled if you simply sold the steel - Again, just my .02 - |
mb911 |
Aug 6 2016, 05:13 PM
A couple of questions to answer. Yes I teach welding and fabrication at a local college. I teach how to properly use cnc brake presses,planishing hammers, English wheels, slip rollers, plate rollers, standard box and pan brakes, shot bags, shrinking and stretching metals.. I have done this for 16 years. Previous I was a welder fabricator in the avaitiob world along with rotax trained to rebuild all of their aviation engine types. Rebuilt 100s of them over the years. Along with that I had my Porsche only business where I designed and built all of the m&k exhaust.. So I guess metal working and engine builds have always been part of my life.. Now to these parts to be honest they take enough time to make that it maybe to costly to retail. I am not sure though. I would say that materials are probably only about 8 dollars per corner with the steel, blending disks, filler metals and argon. That said I believe labor is going to be about 1-1 1/2 hours per corner to make. So price might get up there. Maybe a group but and have laser cuts done Would be the best way to do this? That would help drive the price down Most of the guys here that would want these will have some welding skills. You could offer the cnc'd cut parts, as one option, and welded as another. Cost difference would be the cost of your labor. Each corner would need to be labeled if you simply sold the steel - Again, just my .02 - The problem is that there is extensive forming that needs to be done and probably not by the novice. I have been doing this along time and it is not for the weekend warrior. |
Lo-Fi Version | Time is now: 24th April 2024 - 07:15 PM |
