'74 2L Starts Then Dies, Never a convenient time... |
GregAmy |
Aug 7 2016, 09:43 AM
Advanced Member Group: Members Posts: 2,302 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Nice beautiful New England Day, heading off to the Manchester CT car show and...car won't start. Cranks, a few cylinders fire, then it dies. I cycle the key and hear the pump running and then stop (as before) and same thing: spits then dies.
I tried cycling the key a few times, with the mindset of building more pressure, and it spits a few more cylinders then dies. Even got it to rev a little bit with a half-dozen key cycles, but always dies. Only other symptoms is that I noticed the last time I drove it earlier in the week it was dying when I put in the clutch. Was not consistent, only did ti a few times, but that was unusual behavior. Stock 2L fuel injection, but with cold start and idle air bypass systems disabled; been running fine like this for the several years I've had it. Checked all the relays, each works with the heater blower. Swapping them makes no difference (which I expected, given the pump cycles with the key). My guess is that however the pump is supposed to continue to run after releasing the key, it's not getting the power it needs (just a guess, I've not gotten under there with a voltmeter to verify). The wiring diagrams are not clear (to me) how that power is applied to the fuel pump relay. Any way to quickly salvage my afternoon trip to the car show, or am I using my beautiful afternoon to swap the street car onto the lift for extended diagnosis? 40-yr-old electrics, gotta love 'em. - GA |
GregAmy |
Aug 7 2016, 10:01 AM
So I removed the relay panel harness connector, the one that I think goes to the computer, cleaned it and put some dielectric grease on it...and it starts.
But do I trust it? Well, I do have AAA... Can anyone explain the control functions of the fuel pump on the D-Jet? GA, here we go... |
Lo-Fi Version | Time is now: 19th May 2024 - 06:57 AM |
