'74 2L Starts Then Dies, Never a convenient time... |
GregAmy |
Aug 7 2016, 09:43 AM
Advanced Member Group: Members Posts: 2,302 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Nice beautiful New England Day, heading off to the Manchester CT car show and...car won't start. Cranks, a few cylinders fire, then it dies. I cycle the key and hear the pump running and then stop (as before) and same thing: spits then dies.
I tried cycling the key a few times, with the mindset of building more pressure, and it spits a few more cylinders then dies. Even got it to rev a little bit with a half-dozen key cycles, but always dies. Only other symptoms is that I noticed the last time I drove it earlier in the week it was dying when I put in the clutch. Was not consistent, only did ti a few times, but that was unusual behavior. Stock 2L fuel injection, but with cold start and idle air bypass systems disabled; been running fine like this for the several years I've had it. Checked all the relays, each works with the heater blower. Swapping them makes no difference (which I expected, given the pump cycles with the key). My guess is that however the pump is supposed to continue to run after releasing the key, it's not getting the power it needs (just a guess, I've not gotten under there with a voltmeter to verify). The wiring diagrams are not clear (to me) how that power is applied to the fuel pump relay. Any way to quickly salvage my afternoon trip to the car show, or am I using my beautiful afternoon to swap the street car onto the lift for extended diagnosis? 40-yr-old electrics, gotta love 'em. - GA |
GregAmy |
Aug 30 2016, 05:56 AM
Thanks for the tips.
I don't think it's the fuel pump itself. I replaced mine a couple years ago with a 2-port NAPA pump/kit I got from Chris (Tangerine) so it's probably OK. Plus, it's correlated to temperature of the engine and there's not a lot of temp change up there (it's mounted under the tank). Wiring I can certainly understand. One easy trick I can do is run some wire from the power terminal on the pump to an LED in the cockpit and see if I get a flickering light correlating to this problem. If I do get a flickering then I can move the wires back to the replay board, both output and relay control, and try to nail down where the prob may be. As for the head temp sensor...man, trying to troubleshoot a random problem there will be damned near impossible. Is it correct that the fuel injection shuts off if it doesn't have a good temp reading? If not, what are symptoms of a bad sensor/circuit there? Jeez I hate 40-yr-old wiring. But can't float the cost of a new harness right now. I have four race weekends in a row coming up*, so this is going to be an October project. Thanks for the advice. - GA * LRP Historics (driver observer), SCCA Regional at Palmer (914 race car comes out for the first time), and Mid Ohio SCCA Runoffs (competing). If you're in the area at any of these stop by and say hello, #33 STL Honda Civic Si or orange 914 |
DRPHIL914 |
Aug 30 2016, 06:41 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Thanks for the tips. I don't think it's the fuel pump itself. I replaced mine a couple years ago with a 2-port NAPA pump/kit I got from Chris (Tangerine) so it's probably OK. Plus, it's correlated to temperature of the engine and there's not a lot of temp change up there (it's mounted under the tank). Wiring I can certainly understand. One easy trick I can do is run some wire from the power terminal on the pump to an LED in the cockpit and see if I get a flickering light correlating to this problem. If I do get a flickering then I can move the wires back to the replay board, both output and relay control, and try to nail down where the prob may be. As for the head temp sensor...man, trying to troubleshoot a random problem there will be damned near impossible. Is it correct that the fuel injection shuts off if it doesn't have a good temp reading? If not, what are symptoms of a bad sensor/circuit there? Jeez I hate 40-yr-old wiring. But can't float the cost of a new harness right now. I have four race weekends in a row coming up*, so this is going to be an October project. Thanks for the advice. - GA * LRP Historics (driver observer), SCCA Regional at Palmer (914 race car comes out for the first time), and Mid Ohio SCCA Runoffs (competing). If you're in the area at any of these stop by and say hello, #33 STL Honda Civic Si or orange 914 I might suggest the MPS failing - I had this exact scenario last winter and it ended up being the MPS, - and it held vacuum, its diaphragm was not torn- it was failing electroically - I have a A/F meter- it was failing LEAN not rich like the usual default, so it would do the same thing you are seeing- but yes a CHT circuit shorting out will do this and if the #3 plug wire is close to the CHT wire it can cause interference as well. , - but if I had to guess ? 1. MPS, 2. CHT 3. your grounds for the FI at the back of the case- I had this happen this spring they were vibrating off - and all of a sudden running on 2 cylinders- so check those- I soldered mine on so they would quit coming off and I have a fairly new harness from Jeff B- also #4. check the tightness of the injector connectors they loosen with time - had this happen to me on my way back from Manchester 2 weeks ago after picking the car up from Chris. - Jeff Bowlsby posted a picture on my thread about how to tighten these. - some times the only way is to do the process of elimination - but one thing at a time- try a spare CHT, or MPS first. - and I now have a Pressure gauge in line so I know if the fuel pressure is exactly where it has to be.- my pump recently went out or was on its way out- 5 years old napa pump, but it was still running but making a ton of noise and so I replaced it cause I had a spare Bosch in the shop- like night and day - Good luck, looking forward to hearing which issue it is! oh the fun of 40 year old cars and parts!!!! Phil |
Lo-Fi Version | Time is now: 19th May 2024 - 06:59 AM |
