'74 2L Starts Then Dies, Never a convenient time... |
GregAmy |
Aug 7 2016, 09:43 AM
Advanced Member Group: Members Posts: 2,302 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Nice beautiful New England Day, heading off to the Manchester CT car show and...car won't start. Cranks, a few cylinders fire, then it dies. I cycle the key and hear the pump running and then stop (as before) and same thing: spits then dies.
I tried cycling the key a few times, with the mindset of building more pressure, and it spits a few more cylinders then dies. Even got it to rev a little bit with a half-dozen key cycles, but always dies. Only other symptoms is that I noticed the last time I drove it earlier in the week it was dying when I put in the clutch. Was not consistent, only did ti a few times, but that was unusual behavior. Stock 2L fuel injection, but with cold start and idle air bypass systems disabled; been running fine like this for the several years I've had it. Checked all the relays, each works with the heater blower. Swapping them makes no difference (which I expected, given the pump cycles with the key). My guess is that however the pump is supposed to continue to run after releasing the key, it's not getting the power it needs (just a guess, I've not gotten under there with a voltmeter to verify). The wiring diagrams are not clear (to me) how that power is applied to the fuel pump relay. Any way to quickly salvage my afternoon trip to the car show, or am I using my beautiful afternoon to swap the street car onto the lift for extended diagnosis? 40-yr-old electrics, gotta love 'em. - GA |
GregAmy |
Mar 12 2017, 11:24 AM
30 psi.
See post #32, specifically paragraph 2. |
Dave_Darling |
Mar 13 2017, 03:36 PM
30 psi. See post #32, specifically paragraph 2. All you said was "fuel pressure is 30 psi", with no indication of when it was checked. I did not realize that you had checked it when the car was not starting. If you did, that tends to rule out fuel pressure. So, what we know right now: - Starter cranks - Starting fluid makes the engine start - Fuel pressure is 30 PSI while the starter is cranking - CSV is not hooked up Since the starter cranks, we can rule it out. Starting fluid takes the place of fuel, not of air or spark. So you have air and spark. What you appear to be missing is fuel. But you have fuel pressure even when the car is not starting. BTW, if the pump is wired as per stock it is turned on and off by the FI's ECU, so if the pump runs then you do have power and at least some function of the ECU. Next question: When the car does not start, do you have injector activity? A "noid" light from you FLAPS will tell you if the electrical signals are getting through. If you want to see the activity directly, you can stick one injector in an empty pickle jar while the starter is cranking and the car is in its no-start mode. --DD |
Lo-Fi Version | Time is now: 19th May 2024 - 07:51 AM |
