FS Refinished Trailing arm set $300, Five lug hubs $250, Install you own pivot shaft bushings or I can |
bdstone914 |
Aug 7 2016, 09:13 PM
I have a set of late (72-76) powder coated rear trailing with all related installation parts except for the pivot shaft bushings. Only difference on from the early arms is the bracket for the brake flex line and added drain holes. Can be easily adapted to an early car but not 100% correct. New FAG bearings installed.
I can install Uro or Elephant rubber bushings. I will not install Poly graphite bushings. They suck too much. One arm and related parts is shown. Use your imagination as to what the other one looks like. $300 for the trailing arms and all related installation parts. Also for sale is a pair of five lug hub that are refinished in gold zinc. They have 10.9 grade bolt installed from the back side. $250 for the pair. Sorry for the crappy upside down images. Bruce Attached thumbnail(s) |
Lo-Fi Version | Time is now: 18th May 2024 - 03:19 PM |
