WET SANDBLASTING A 914 |
Curbandgutter |
Aug 10 2016, 04:45 PM
Senior Member Group: Members Posts: 564 Joined: 8-March 13 From: Murrieta CA Member No.: 15,637 Region Association: Southern California |
Well I'm getting ready to wet sand blast (WSB) my project car and I wanted some input form those who have done it and or have some direct or indirect experience with it. I purchased a wet sand blasting kit from a company back east. I tried a sample piece and was thoroughly impressed. I was able to remove the paint down to bare metal on the underside floor in under 5 minutes. It was incredibly fast. The primer that I am using is an epoxy primer by SPI. I spoke with the manufacturer and they said to steer away from using a rust convertor as they can be very tricky to remove from seams. They also said to just blast it and spray it the next day. The flash rust will not be a problem. What has been your experience
Tom_T |
Aug 10 2016, 04:54 PM
I know that the guy at my shop wont sandblast at all because the media is too aggressive, & can warp the panels.
As for waiting to the next day to spray the primer - especially with wet sand/media - since I've had flash rust over night when I wire wheeled small areas & thoust it would be okay overnight (I'm also in relatively dry SoCal). You might consider using soda or walnut shells or other less aggressive media for blasting. Hopefully Rick/Alien or some of the other body shop members will chime in here on your question. Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Lo-Fi Version | Time is now: 14th May 2024 - 02:34 AM |
