WET SANDBLASTING A 914 |
Curbandgutter |
Aug 10 2016, 04:45 PM
Senior Member Group: Members Posts: 564 Joined: 8-March 13 From: Murrieta CA Member No.: 15,637 Region Association: Southern California |
Well I'm getting ready to wet sand blast (WSB) my project car and I wanted some input form those who have done it and or have some direct or indirect experience with it. I purchased a wet sand blasting kit from a company back east. I tried a sample piece and was thoroughly impressed. I was able to remove the paint down to bare metal on the underside floor in under 5 minutes. It was incredibly fast. The primer that I am using is an epoxy primer by SPI. I spoke with the manufacturer and they said to steer away from using a rust convertor as they can be very tricky to remove from seams. They also said to just blast it and spray it the next day. The flash rust will not be a problem. What has been your experience
mbseto |
Aug 11 2016, 12:19 PM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
Need a nitrogen atmosphere paint booth.
Jeff Hail |
Aug 11 2016, 12:57 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
worn |
Aug 11 2016, 02:44 PM
can't remember Group: Members Posts: 3,154 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Need a nitrogen atmosphere paint booth. Not really. Nitrogen does not carry moisture. You need atmosphere to bind water or solvent molecules to carry them away. But nitrogen does not easily create rust, which would be nice. The time when the sand from wherever becomes most apparent is when the spray gun mixes it out of the crevices and straight into the paint. Not fun at all. |
Lo-Fi Version | Time is now: 14th May 2024 - 01:31 AM |
