WET SANDBLASTING A 914 |
Curbandgutter |
Aug 10 2016, 04:45 PM
Senior Member Group: Members Posts: 564 Joined: 8-March 13 From: Murrieta CA Member No.: 15,637 Region Association: Southern California |
Well I'm getting ready to wet sand blast (WSB) my project car and I wanted some input form those who have done it and or have some direct or indirect experience with it. I purchased a wet sand blasting kit from a company back east. I tried a sample piece and was thoroughly impressed. I was able to remove the paint down to bare metal on the underside floor in under 5 minutes. It was incredibly fast. The primer that I am using is an epoxy primer by SPI. I spoke with the manufacturer and they said to steer away from using a rust convertor as they can be very tricky to remove from seams. They also said to just blast it and spray it the next day. The flash rust will not be a problem. What has been your experience
Mark Henry |
Aug 12 2016, 09:15 AM
Actually this looks interesting and you can get cheap ones now. Not pro models, but it may be all you need for a few jobs. You could use it to augment regular blasting and stripping, get all the heavy rust off, then sand and dry blast off any flash.
The big thing would be prep, blocking all holes to keep the sand out. |
Lo-Fi Version | Time is now: 13th May 2024 - 08:15 PM |
