WET SANDBLASTING A 914 |
Curbandgutter |
Aug 10 2016, 04:45 PM
Senior Member Group: Members Posts: 564 Joined: 8-March 13 From: Murrieta CA Member No.: 15,637 Region Association: Southern California |
Well I'm getting ready to wet sand blast (WSB) my project car and I wanted some input form those who have done it and or have some direct or indirect experience with it. I purchased a wet sand blasting kit from a company back east. I tried a sample piece and was thoroughly impressed. I was able to remove the paint down to bare metal on the underside floor in under 5 minutes. It was incredibly fast. The primer that I am using is an epoxy primer by SPI. I spoke with the manufacturer and they said to steer away from using a rust convertor as they can be very tricky to remove from seams. They also said to just blast it and spray it the next day. The flash rust will not be a problem. What has been your experience
Mark Henry |
Aug 26 2016, 08:13 AM
So this was the result of my quick test shot. As I said I don't have any Holdtight 102 (I need to find a canadian distributor) it's fairly high humidity out and I didn't dry it proper. Not to mention it was after dark and I wasn't dressed proper.
So it's starting to flash, but even with the flash it took off the heavy rust PDQ. If I just went from here and hit it with the dry blaster it would clean up damn fast. The last pic of the back of the rim shows how heavy the rust was on most of the face. As said you would have to be super careful if doing the body, but it will definitely be a useful tool. Attached image(s) |
Lo-Fi Version | Time is now: 14th May 2024 - 01:11 PM |
