1970 914/6 Harness Horror, Main Wiring Harness Connection |
Howie149 |
Aug 10 2016, 08:42 PM
Newbie Group: Members Posts: 4 Joined: 10-August 16 From: Emerald Hills, CA Member No.: 20,286 Region Association: None |
I have a 1970 914/6. When I pulled the motor out, the 14 pin Main Harness that sits on the Relay Board in the engine compartment came apart. Thus I have no idea which wire goes where. I have 6 wires. (2 are grey and black and go to the transmission back-up switch/sender. 1 Green and brown and 1 Green and black go to the oil pressure and oil level senders. 1 Black and red goes to the coil and I'm not sure about the black and blue/purple.) I have attached a picture of the harness below.
I would enjoy any guidance on where to plug these wires. Car won't start and it keeps blowing fuses which I assume is either a problem with these wires or the ignition system/distributor needs an overhaul. Attached thumbnail(s) |
Dion |
Aug 11 2016, 10:44 AM
RN Group: Members Posts: 2,766 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
Why do you have a tach adapter ? I was thinking the same thing...if it's a real /6 there's no need. Maybe it's a conversion? I think I remember reading the tach adapt can also smooth out signals if the original tach is too bouncy. |
Lo-Fi Version | Time is now: 19th May 2024 - 01:42 PM |
