1970 914/6 Harness Horror, Main Wiring Harness Connection |
Howie149 |
Aug 10 2016, 08:42 PM
Newbie Group: Members Posts: 4 Joined: 10-August 16 From: Emerald Hills, CA Member No.: 20,286 Region Association: None |
I have a 1970 914/6. When I pulled the motor out, the 14 pin Main Harness that sits on the Relay Board in the engine compartment came apart. Thus I have no idea which wire goes where. I have 6 wires. (2 are grey and black and go to the transmission back-up switch/sender. 1 Green and brown and 1 Green and black go to the oil pressure and oil level senders. 1 Black and red goes to the coil and I'm not sure about the black and blue/purple.) I have attached a picture of the harness below.
I would enjoy any guidance on where to plug these wires. Car won't start and it keeps blowing fuses which I assume is either a problem with these wires or the ignition system/distributor needs an overhaul. Attached thumbnail(s) |
Perry Kiehl Clone |
Aug 11 2016, 08:16 PM
Unregistered |
Looks like it could be one of my harnesses, or maybe a from a kit I sold. On a 914-6 the tach wire is black with a blue tracer. I've been swamped with a house project. I'll get the color coding and pin outs tomorrow. It really isn't hard to ohm out the wires and see where they are connected.
Lo-Fi Version | Time is now: 19th May 2024 - 10:56 AM |
