Falken Azenis tire pressures for AX |
Racer |
Aug 11 2016, 06:07 PM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
So.. I found one of the few sporty tires for 14" rims for my 914. Falken Azenis RT615-Ks. 195-60-14.
So far, I really like them. However, I can't seem to tell a good pressure for them at AX. First even started at 35 cold all around.. felt ok, and kept bleeding down to 35 as they heated up. Car felt good, but did feel as they heated up I was losing grip, hence the bleed downs during the day Second event, didn't check cold (slow brain) but bleed them down, hot to 32ish. Couldn't really tell if they were better or worse than 35 hot... My previous 914 and R comp experience was 205-50-15s (smaller sidewall) of Yoke A008, A032rs, Kumho Victoracers, RA-1s. For those, I never ran more than 30hot. What could be skewing my memory/preferences is the last 3-4 years I ran a stock 1987 944, 215-60-15s Fuzion xxxx's and they really felt good at 35 hot all around. Thoughts? Should I be closer to 30 hot with these too? Perhaps I fear too much sidewall flex for the 60 series tire... |
Jetsetsurfshop |
Aug 12 2016, 04:29 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
I was told your air pressure should match the vehicles weight.
10lbs for every thousand pounds. Of course its just a guide. We ran those tires for Chumpcar last year and George worked on the tire pressures during the pit stops. I think our hot pressures were like 22 front/24 rear. I could be wrong, I was on gopro duty. Never AXed them though.... (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 06:08 PM |
