Can the push rod tube O-Rings be installed in situ?, Is there a trick / technique that works ? |
Beebo Kanelle |
Aug 13 2016, 04:08 PM
Member Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region |
I am getting a few leaks in the push rod tubes.
I bought some Viton O-Rings tho replace the old ones. Can this be done with the engine in the car? With the exhaust on the car? If anybody has done this, has tricks, or a technique that works, please share. Thank you in advance. |
Lo-Fi Version | Time is now: 19th May 2024 - 03:24 AM |
