| tornik550 |
Aug 14 2016, 02:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I have a set of MSDS /6 headers and it appears that my handbrake cables sit right on the headers. I haven't started the engine yet cause they will obviously melt. Anyone else have this issue and if so what did you do?
| Krieger |
Aug 14 2016, 03:27 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,842 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
I have them on my 3.0. The cable on the driver side does when I have the car lifted up and the trailing arm is down. It ends up touching the bottom of the headers. I have to make sure when the car is on the ground the cable is positioned over the header.
| Mark Henry |
Aug 14 2016, 04:14 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Yep, once your 914 is on the ground it's no longer on the header.
If you're worried about it you could run the cable through a section of fire sleeve. https://www.aircraftspruce.ca/catalog/appag...qfiresleeve.php |
| tornik550 |
Aug 14 2016, 04:33 PM
Thank you to everyone for the advice. I had never looked with the car on the ground. The cables now are not resting on the headers.
Just for future reference- does fire wrap work even if it is resting directly on a high heat source like a header? |
| Mark Henry |
Aug 14 2016, 05:40 PM
Likely no, it's meant for close proximity and temporary contact, but the correct hose with the correct clamps is what the FAA calls "fireproof". Constant contact with a header the cover might not fail, but what's inside might bake till it fails.
If it only monetarily touches the headers you will be fine. QUOTE "Fire-proof" hose lines as defined by FAA must withstand a direct flame for fifteen minutes under specified flow conditions without failure. |
Lo-Fi Version | Time is now: 14th March 2026 - 06:17 AM |
