dirk says HOWDY!! in a small way., spark plugs for mallory dist, coil, etc |
rhodyguy |
Apr 13 2005, 08:01 AM
what are your plug recommendations for the mallory setup? bosch or ngk, i would like to have a couple of purchase options. my understanding is the W7CC may not be the optimum style for the upgrade.
k |
tat2dphreak |
Apr 13 2005, 08:03 AM
i *think* Jake uses the NGKs...
rhodyguy |
Apr 13 2005, 08:16 AM
i need the specific plug numbers.
k |
rhodyguy |
Apr 13 2005, 08:40 AM
well. anyone? (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
k |
tat2dphreak |
Apr 13 2005, 08:47 AM
5829-DP8EA-9-NGK
rhodyguy |
Apr 13 2005, 08:54 AM
tat2dphreak |
Apr 13 2005, 08:57 AM
sure thing!! |
Brett W |
Apr 13 2005, 09:56 AM
You need a B7ES for most mods. If you are running a lot of road racing, juice, boost, or really high compression ratio on pump gas you should start with a B8ES. If you do a lot of low rpm running with carbs and in cool weather you might start with a B6ES.
Lo-Fi Version | Time is now: 15th May 2024 - 05:12 AM |
