zeniths on a 914/6 |
76racer |
Aug 15 2016, 06:47 PM
Newbie Group: Members Posts: 16 Joined: 19-August 11 From: Ontario, Canada Member No.: 13,463 Region Association: Canada |
Hi, does anybody know if Zeniths ever came stock on 914/6? My buddy acquired an old 6 motor that came with Zeniths on it and they look like they've been there a long time.
thanks Joe |
mepstein |
Aug 15 2016, 06:51 PM
914-6 GT in waiting Group: Members Posts: 19,277 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Webers were stock
forrestkhaag |
Senior Member Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
Sounds like an early 911 engine that originally came with Zenith's and not related to 914-6 Weber applications.. Others with alot more info will clarify..
(IMG:style_emoticons/default/beerchug.gif) |
forrestkhaag |
Aug 15 2016, 06:53 PM
Agree with Mark / the set of triples I now have for my 6 build match the original 914-6 build.. (IMG:style_emoticons/default/beerchug.gif)
barefoot |
Aug 15 2016, 09:21 PM
Senior Member Group: Members Posts: 1,276 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
According to Bruce Anderson, 911E in 1970/71 had Zenith 40 TIN's,
seems to be only applications |
bretth |
Aug 15 2016, 10:26 PM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
I thought 70-71 911E had FI and the 911T had the budget Zenith carbs. I have a set of Zeniths would the part numbers on them give a clue what they came from?
Brett |
mountainroads |
Aug 15 2016, 10:52 PM
Member Group: Members Posts: 210 Joined: 19-February 12 From: Seattle Member No.: 14,145 Region Association: Pacific Northwest |
According to Bruce Anderson, 911E in 1970/71 had Zenith 40 TIN's, seems to be only applications Sorry: ALL 911E's, 1969 - 1973, came from the factory with Mechanical Fuel Injection (MFI. "E" for Einspritzung.) As Bretth said: Zeniths were a 911T, 1969 - 1972/1973 (?) application. - MR |
Toast |
Aug 15 2016, 11:05 PM
Not bad for carrying sway bars. Group: Members Posts: 3,377 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region |
All I can say is DONT DO IT!!
I've had zenith carb....and they are the worst thing Ever!! Unless you like working on carbs all the time... |
oldie914 |
Aug 16 2016, 03:00 AM
Member Group: Members Posts: 102 Joined: 2-May 10 From: Germany Member No.: 11,680 Region Association: None |
In 1970-71, the US version of the 911T (2.2ltr) had Zenith carbs. The German version had Weber 40IDT3C. The engine in question probably has Zenith carbs from a 2.2ltr engine or is a 2.2 engine. Check the serial number.
The Zeniths were trouble even when they were new; the idle circuits would stop up. Bolt on a set of Webers and the problem was gone. The 1972 European 2.4T engine had Zeniths, the US version had MFI. Both engines were changed to CIS injection during the 72 or 73 model year. |
rgalla9146 |
Aug 16 2016, 04:27 AM
Advanced Member Group: Members Posts: 4,559 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
In 1970-71, the US version of the 911T (2.2ltr) had Zenith carbs. The German version had Weber 40IDT3C. The engine in question probably has Zenith carbs from a 2.2ltr engine or is a 2.2 engine. Check the serial number. The Zeniths were trouble even when they were new; the idle circuits would stop up. Bolt on a set of Webers and the problem was gone. The 1972 European 2.4T engine had Zeniths, the US version had MFI. Both engines were changed to CIS injection during the 72 or 73 model year. CIS came in 1973. The switch came to be known as 1973 and a half. |
Mike Fitton |
Aug 16 2016, 07:26 AM
Senior Member Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest |
My '71 Targa has Zenith's and they run great, if you are having problems with them then you have someone working on them that don't know what they are doing. When they get dialed in right they run better than my webers on m 914-6.
injunmort |
Aug 16 2016, 07:30 AM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
zeniths on my 1970 911t 2.2l
barefoot |
Aug 16 2016, 08:09 AM
According to Bruce Anderson, 911E in 1970/71 had Zenith 40 TIN's, seems to be only applications Sorry: ALL 911E's, 1969 - 1973, came from the factory with Mechanical Fuel Injection (MFI. "E" for Einspritzung.) As Bretth said: Zeniths were a 911T, 1969 - 1972/1973 (?) application. - MR Bruce got it wrong eh ? |
mountainroads |
Aug 16 2016, 08:25 AM
According to Bruce Anderson, 911E in 1970/71 had Zenith 40 TIN's, seems to be only applications Sorry: ALL 911E's, 1969 - 1973, came from the factory with Mechanical Fuel Injection (MFI. "E" for Einspritzung.) As Bretth said: Zeniths were a 911T, 1969 - 1972/1973 (?) application. - MR Bruce got it wrong eh ? I'd have to look at the book for myself before claiming that. If that is indeed what is printed, then yes - either a mistake or a misprint. In some ways, it's surprising that the 914-6 *didn't* come with Zenith carbs, since the engine is essentially a 1969 911T. - MR |
brant |
Aug 16 2016, 08:43 AM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
[/quote]
I'd have to look at the book for myself before claiming that. If that is indeed what is printed, then yes - either a mistake or a misprint. In some ways, it's surprising that the 914-6 *didn't* come with Zenith carbs, since the engine is essentially a 1969 911T. - MR [/quote] Correct no zeniths came in the US on the 914/6 zeniths came in the US on the 70-71T 911 I would have to look back at the 69T - 911, but almost positive it had webers the 72 - 911T came with MFI the 73 - 911T came with the CIS (small spigot 7R case one year only) I need another one of these cases for the race car if anyone wants to let one go affordably. I believe that the Zeniths in the US were unique to the 2.2 911T cars |
mepstein |
Aug 16 2016, 09:03 AM
The 69T we restored had Webers. So 99.9% sure.
Mark Henry |
Aug 16 2016, 09:41 AM
Zeniths are OK, just there is no parts for them.
The weber IDA has parts, many parts are reproduced, big selection oversize vents and jets and main things like jets, etc., are the same as the 2 barrel IDA the bug guys use. Not to mention that both the 2 and 3 barrel (PMO) are reproduced. |
jd74914 |
Aug 16 2016, 09:42 AM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Correct no zeniths came in the US on the 914/6 zeniths came in the US on the 70-71T 911 I would have to look back at the 69T - 911, but almost positive it had webers the 72 - 911T came with MFI the 73 - 911T came with the CIS (small spigot 7R case one year only) I need another one of these cases for the race car if anyone wants to let one go affordably. I believe that the Zeniths in the US were unique to the 2.2 911T cars You do also have to watch for the ROW 2.4 911TV cars which came with Zeniths (vs. the 911TE with FI in the USA). My dad bought a 911 a while ago with a TV motor in it and we were a bit confused for a while. They definitely existed in '72, but I'm not totally sure about '73. |
mepstein |
Aug 16 2016, 09:51 AM
Zeniths are OK, just there is no parts for them. The weber IDA has parts, many parts are reproduced, big selection oversize vents and jets and main things like jets, etc., are the same as the 2 barrel IDA the bug guys use. Not to mention that both the 2 and 3 barrel (PMO) are reproduced. Same issues with PMO's. Nice carbs but parts only available from one place - PMO. |
GeorgeRud |
Aug 16 2016, 11:21 AM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Paul Abbot @ Performance Oriented has been working on modifying the Zeniths. If properly set up, they should work.
Lo-Fi Version | Time is now: 20th May 2024 - 02:40 PM |
