Seat Adjuster Handle Question, Question, suggestion, help? |
Tburt52359 |
Aug 20 2016, 02:52 PM
Newbie Group: Members Posts: 49 Joined: 24-May 15 From: Orange County Member No.: 18,756 Region Association: Southern California |
I am attempting to replace a seats adjustment handle [entire piece). At the no of the assembly there is a rivet at the pivot point. What are my options to remove it?
Or would I be better off trying to find a whole assembly with the handle already attached from someone out there? If so does someone out there have one they would like to get rid of. Thanks in advance. Attached thumbnail(s) |
RAX914 |
Aug 20 2016, 02:58 PM
Member Group: Members Posts: 99 Joined: 20-August 14 From: California Member No.: 17,801 Region Association: None |
914rubber sells replacement handles, if that's all you need to replace:
http://shop.914rubber.com/914-Seat-Adjuste...ndle-914SH1.htm |
914 RZ-1 |
Aug 20 2016, 03:25 PM
Porsche Padawan Group: Members Posts: 682 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
Nevermind, I thought you were asking about the rivets that hold the seat handle to the rail.
Tburt52359 |
Aug 20 2016, 03:40 PM
914Sixer |
Aug 21 2016, 06:27 AM
914 Guru Group: Members Posts: 8,868 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Put a want to buy over in the Classified section, some one should be able to help
Mike Fitton |
Jan 17 2017, 11:04 PM
Senior Member Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest |
I want to replace this whole piece also, has anyone taken this whole piece out and replaced it (not just the handle)? Anyone know what type of rivet needed to install this whole piece at the pivot point towards the back of the rail?
Mike Fitton |
Jan 18 2017, 07:37 AM
Figured it out. Press fit rivet cap on one end of a solid metal pin. Drilled the rivet cap off and tapped the pin out. Easy to reinstall the pin fits tight and probably doesn't need another rivet cap on re-install, just some grease.
Mikey914 |
Jan 18 2017, 10:26 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The big problem with these are the drivers side. I would suggest if you reinstall you swap the two handles as they are pot metal and do fatigue. This will buy you more time.
Lo-Fi Version | Time is now: 23rd April 2024 - 07:43 PM |
