more overthinking, Full Flow oil pump again |
crash914 |
Aug 21 2016, 09:58 AM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
So, with the type1 oil pump and the remote oil filter and block off plate installed,
is it recommended to plug the pump outlet? I would think that the oil would just deadhead in the galley that used to go to the filter. but there would be an air chamber there that might cause issues. I have seen both plug an not to plug recommendations. Which is best? TIA.... |
Mark Henry |
Aug 21 2016, 10:12 AM
Plug it... it's a simple job.
crash914 |
Aug 21 2016, 11:32 AM
taps are already out for case plugs...I just did not know if adding a plug would change anything..like you said, simple to do now...
Now if I had one of those trick yellow motor mounts........ |
Mark Henry |
Aug 21 2016, 11:46 AM
taps are already out for case plugs...I just did not know if adding a plug would change anything..like you said, simple to do now... Now if I had one of those trick yellow motor mounts........ PM me Herb I'll tell you how to make it or I'll make one for you. (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 10th May 2024 - 08:15 AM |
