Aftermarket distributor, Since Malory is NLA what's the choice? |
BigFour1973 |
Aug 21 2016, 08:10 PM
Member Group: Members Posts: 187 Joined: 16-November 14 From: Long Beach Member No.: 18,126 Region Association: Southern California |
After admiring all the 914s at cars and coffee I noticed a couple cars running the Malory dizzy unit. I've been looking into them and since they're discontinued I can't find any new literature on what is new.
What are you using and why is it better then that guys? |
Elliot Cannon |
Aug 21 2016, 08:19 PM
I have been using this one for about 5 years. The cooling tin had to be "massaged" a little to make it fit. It's a bit larger in diameter. I have had NO problems with it at all.
Dominic |
Aug 21 2016, 08:51 PM
Dominic Group: Members Posts: 992 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
CB Performance sells MagnaSpark centrifugal Distributors and Digital (fully programmable) distributor.
http://www.cbperformance.com/Magnaspark-Ki...Parts-s/218.htm I have the digital (programmable) one and it works great. Of course you may have to modify the engine tin on a stock engine. |
pete000 |
Aug 21 2016, 10:25 PM
I was pondering this one. 123 ignitions form Europe.
Not cheap but plug and play, fully programmable. There is a German You Tube video of an impressive 2.0 using this. https://www.youtube.com/watch?v=F1PFb46gKlc https://www.youtube.com/watch?v=tYGX5B8Yj58 https://www.youtube.com/watch?v=rw1FigYoozE http://www.123ignition.nl/ |
ThinAir |
Aug 21 2016, 10:51 PM
Best friends Group: Members Posts: 2,542 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
These are all for folks with carbs or non-stock FI, right?
BigFour1973 |
Aug 21 2016, 10:59 PM
I have been using this one for about 5 years. The cooling tin had to be "massaged" a little to make it fit. It's a bit larger in diameter. I have had NO problems with it at all. Did you have to use any sort of inline module to keep the rpm gauge working? I was reading that the rpm gauge doesn't register multi spark systems? |
Elliot Cannon |
Aug 22 2016, 12:50 AM
I have been using this one for about 5 years. The cooling tin had to be "massaged" a little to make it fit. It's a bit larger in diameter. I have had NO problems with it at all. Did you have to use any sort of inline module to keep the rpm gauge working? I was reading that the rpm gauge doesn't register multi spark systems? Not that I know of. I didn't do the installation. (IMG:style_emoticons/default/confused24.gif) |
Mark Henry |
Aug 22 2016, 01:04 AM
Buy a used mallory red cap dual point and convert it to a Pertronix.
Megajolt Jr crankfire, distributorless and programmable. |
McMark |
Aug 22 2016, 05:42 AM
I just installed a 123Ignition distributor on a car. Really liked the quality of the build. This one was the Bluetooth unit that you can tune from your phone. Haven't run the car yet, but will next weekend. (IMG:style_emoticons/default/wink.gif)
Lo-Fi Version | Time is now: 11th May 2024 - 04:35 PM |
