914 6 calipers rear limited reproduction run GB?, Built by PMB $799 A set |
ConeDodger |
Aug 25 2016, 03:20 PM
Apex killer! Group: Members Posts: 23,605 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
The cast alloy calipers appear to be made from patterns matching the original calipers. Shouldn't the patterns have been substantially enlarged (increased wall and rib thicknesses, etc) to account for use of the weaker alloy aluminum material? If you look close in this picture, you'll see my alloy - Alfa Romeo GTV-6 brakes. The have the same bolt pattern as the stock 4 cylinder fronts. They seem to me to be about the same size as the stock 4 cylinder fronts. I have tortured the living snot out of these two front calipers and I can't even wear the pads out! Remember, we're talking about alloy rear calipers. The rear calipers job is to make you stop straight and not much more. The possibility of vibration or flex has been handled with the larger hardware. So if the fronts can be the same size as their iron alternative (and they do the bulk of the work) why would the rears need to be bigger? What is it you think might happen? Attached image(s) |
Aug 25 2016, 03:38 PM
914-6 GT in waiting Group: Members Posts: 19,305 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The cast alloy calipers appear to be made from patterns matching the original calipers. Shouldn't the patterns have been substantially enlarged (increased wall and rib thicknesses, etc) to account for use of the weaker alloy aluminum material? Early Aluminum S calipers weren't really any larger than steel M calipers. The 914-6 GT seemed to do just fine. The rear aluminum calipers seem to be plenty beefy for the job. Probably overkill. Don't knock it till you try it. |
NeunEinVier |
Aug 25 2016, 04:35 PM
Member Group: Members Posts: 110 Joined: 24-December 15 From: In front of the smoke. Member No.: 19,488 Region Association: None |
The engineers of the OEM calipers must have designed the iron caliper to be many times stronger than necessary, so it's still adequate when cast in aluminum.
You'd think the engineers would have designed the iron calipers to be as light as possible (for performance and less manufacturing material), but apparently they wanted a larger safety margin and went for overkill. |
Mikey914 |
Aug 25 2016, 05:21 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Let me say this. The calipers that were cast in aluminum are not an identical copy.
jd74914 |
Aug 25 2016, 05:37 PM
The possibility of vibration or flex has been handled with the larger hardware. I read the fastener size increase on PMB's website, but I don't quite know what is has to do with anything in terms of caliper stiffness. I get increasing fastener size as a way to reduce bearing stress on the fastener surface since larger diameter fasteners also have larger surface area bolt/nut heads. The would help if there was concern of boss cracking after some number of cycles. It seems easier to get 8mm fasteners in all strengths which would be a primary driver for me to change fastener size... The engineers of the OEM calipers must have designed the iron caliper to be many times stronger than necessary, so it's still adequate when cast in aluminum. You'd think the engineers would have designed the iron calipers to be as light as possible (for performance and less manufacturing material), but apparently they wanted a larger safety margin and went for overkill. Yeah, I would have thought they would have done some more optimization too. On the other hand, metal was cheaper in the '70s and 3D FEA wasn't really a thing so maybe the cost of optimization through prototyping was too high? Are they iron? Or steel? I feel like they are probably steel since it has so much better resistance to crack propagation from casting porosity, etc. What is it you think might happen? My concern is always fatigue life with aluminum parts. The problem is that you don't know there is a problem until maybe years later if you are in the high cycle fatigue region. Aluminum has a significantly smaller stress amplitude limit (about 3x less) than steel for the no endurance limit case (ie: the point they will never ever break). PMB says the calipers flex 0.002" (not really meaningful since it doesn't equate that to any clamping force, etc. but) which is an order of magnitude less than some racecar calipers I've used, but we replaced those pretty frequently too. (IMG:style_emoticons/default/rolleyes.gif) From a sudden failure perspective, IIRC aluminum's fracture toughness/yield strength ratio is a bit better than cast iron so you're more likely to deform the things than crack them from a casting imperfection which is probably good. Of course, it the OEM calipers are steel the converse is true. The rear aluminum calipers seem to be plenty beefy for the job. Probably overkill. Don't knock it till you try it. Just so everyone knows, my comments here aren't to knock them. They just worry me a bit long term since the amount of analysis into them isn't publicized. I'd love to see it though! (IMG:style_emoticons/default/biggrin.gif) |
rhodyguy |
Aug 25 2016, 07:18 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Mark, were the aluminum calipers halves cast from a 'match plate' pattern?
Mikey914 |
Aug 25 2016, 10:41 PM
Guys, this thread is about the steel calipers.
raynekat |
Aug 30 2016, 06:12 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Mark:
How do I get a set of these steel calipers built up? Would want the spacers so I can run vented discs. Thanks ps replied to the For Sale ad as well.... |
Mikey914 |
Aug 31 2016, 11:29 PM
I can have Eric Build them up. The spacers for vented are a $40 adder (4pcs), but I'll ask him to do up on of the 3 that way. There are only 4 left including the 3 that are being build. 20 of the 3 are spoken for, so actually only 2 sets left and there will be no more.
raynekat |
Sep 1 2016, 01:09 AM
Mark, I need a set of these with the spacer so I can run the vented rotors.
Let me know how to proceed...like where to send a deposit or whatever funds you need to get this going. Thanks |
Lo-Fi Version | Time is now: 1st June 2024 - 02:22 AM |
