wtd: 911 front hub grease caps |
barrym |
Aug 28 2016, 01:37 AM
Member Group: Members Posts: 88 Joined: 12-October 14 From: Australia Member No.: 18,008 Region Association: None |
as per the title - want a pair of them for my 5 stud 911 conversion ...
PM me ? Thanks |
sixaddict |
Aug 28 2016, 05:10 AM
Senior Member Group: Members Posts: 781 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
914Sixer |
Aug 28 2016, 02:47 PM
914 Guru Group: Members Posts: 8,840 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
The part number on the hubs will determine which cap you need.
barrym |
Aug 28 2016, 03:06 PM
Thx, I'll grab a part # from the hub, I do know it's a 58mm od hub if that helps ?
Larmo63 |
Aug 28 2016, 07:23 PM
There are "outies" and "innies."
barrym |
Aug 29 2016, 04:31 AM
ok - hub part # is 901 341 605 3R
the grease cap has to slot on the outside of the hub |
bdstone914 |
Aug 29 2016, 07:12 AM
bdstone914 Group: Members Posts: 4,496 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
sixaddict |
Aug 29 2016, 07:42 AM
I am glad Mark and Bruce are competent purveyors of technical information. I knew only that I picked up outies and needed innies. Always great sources here and buying new from Pelican means you will get the right stuff quickly as surprisingly these things are harder to find than one would think they should be .
bdstone914 |
Aug 29 2016, 06:31 PM
I am glad Mark and Bruce are competent purveyors of technical information. I knew only that I picked up outies and needed innies. Always great sources here and buying new from Pelican means you will get the right stuff quickly as surprisingly these things are harder to find than one would think they should be . Thanks. Have to check with Porsche as to availability. For some reason they get lost. I buy used ones when i canfind them. Do not have any extras. The innies are twice the price. Bruce |
bdstone914 |
Aug 29 2016, 07:36 PM
dupe post
Lo-Fi Version | Time is now: 28th March 2024 - 03:54 AM |
