1974 fuse S9 |
1974 fuse S9 |
Porscheguy912 |
Aug 28 2016, 01:41 PM
porscheguy912 Group: Members Posts: 46 Joined: 10-April 14 From: Summit, NJ Member No.: 17,236 Region Association: North East States |
Friends, continuously blowing fuse S9 on 1974 2.0. Any suggestions?
Thanks |
JeffBowlsby |
Aug 28 2016, 03:52 PM
914 Wiring Harnesses Group: Members Posts: 8,485 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Attached image(s) |
914Bryan |
Aug 28 2016, 05:57 PM
Member Group: Members Posts: 190 Joined: 6-June 11 From: Orange County Member No.: 13,162 Region Association: Southern California |
From what fuse would I wire up my radio from? |
PancakePorsche |
Aug 29 2016, 01:08 AM
Member Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None |
Most radio installs had a in-line fuse holder on the 12+ radio wire, connected to un-fused, switched 12+ buss on plate. Use 5A or less fuse !
Porscheguy912 |
Aug 29 2016, 06:08 AM
Dear Jeff, what might make that fuse blow each time I start the car?? Thanks Gregory |
Mueller |
Aug 29 2016, 07:55 AM
Dear Jeff, what might make that fuse blow each time I start the car?? Thanks Gregory I'm not Jeff, but I driven with him! I'd look for a broken wire and if you cannot find one then remove bulbs and start putting them back in. Have you replaced a bulb lately? Correct bulb? Nothing broke or twisted when installing it? |
Dave_Darling |
Aug 29 2016, 03:31 PM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
If S9 blows every time you turn your headlights (or just parking lights) on, look for license plate lights that have been wired backwards... Yes, the ground/power does matter!
--DD |
76-914 |
Aug 29 2016, 03:53 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) Also, those license wires are known to be a PITA and can easily short where they pass thru the rear panel (missing grommet) or where the little spade connectors short out against the bumper. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 2nd May 2024 - 01:41 AM |
