WTB stock heads/Head work question, Questions on heads. |
Localboy808 |
Aug 28 2016, 01:57 PM
Member Group: Members Posts: 185 Joined: 17-July 16 From: Palmdale, Ca Member No.: 20,194 Region Association: None |
So. Did a compression check on my new 914. 90/90/85/90. Adjusted the valves. No change. Added some oil to one cylinder. No change. I'm guessing valves. When I got this car it had a bad exhaust leak. Come to find it was missing all the copper gaskets at the head and both collector gaskets. I'm not the expert when it comes to heads. But I'm guessing the missing gaskets could have caused some damage at the valves? Especially if it was driven a lot like that? So my question is. Any recommendations for someone on a budget? They are four bolt intakes so 1.7 or 1.8 heads. Not sure really. Anyone have a used decent set for sale? Any advice as far as getting them rebuilt? I'm in So Cal.
Thanks! Scott |
dlee6204 |
Aug 28 2016, 06:08 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
The closest place to take the two heads to in LA is , European Motors in Hawthorne. They will also have heads if you simply want to swap them out...parts too. Contact is Jorge.....they've been working on these type fours for awhile now. Good luck (IMG:style_emoticons/default/agree.gif) I second this. My 1.7 heads took about 2 weeks to do and about 300 bucks for a simple refresh. New guides, valve grind, cleaning & blasting. |
Lo-Fi Version | Time is now: 17th May 2024 - 06:22 PM |
