WTB: Rear Targa Latches |
tbox56 |
Aug 28 2016, 09:18 PM
Member Group: Members Posts: 54 Joined: 14-November 04 From: Colorado Member No.: 3,115 |
I'm looking for a good, either restored, or relatively unused rear targa latches, for a reasonable price.
Thank you, |
bdstone914 |
Aug 28 2016, 09:48 PM
bdstone914 Group: Members Posts: 4,496 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
tbox56 |
Aug 29 2016, 07:52 AM
I should be able to assemble a pair from powder coated parts. I can check tomorrow. $60 for the pair shipped. Bruce Sounds good, Let me know! Are the shafts where the hook pivots in good shape? When i was looking at mine, they were pretty worn on the outside where the spring pulls them, which was, as far as I can tell, causing my issues. Do you need cores back? I'd be happy to send mine. |
bdstone914 |
Aug 29 2016, 07:58 AM
Show me a picture of yours. There are two variations. Yes I can use cores.
bdstone914 at bdstone914 at aol dot com Bruce |
tbox56 |
Aug 29 2016, 08:05 AM
Show me a picture of yours. There are two variations. Yes I can use cores. bdstone914 at bdstone914 at aol dot com Bruce The car is 120 miles away right now. I can get pics next weekend, or if you have pics of the two different ones, I can probably tell the difference. As far as I know, mine are original off a '72, if that helps. Are the two different variations interchangeable? |
bdstone914 |
Aug 29 2016, 06:27 PM
Show me a picture of yours. There are two variations. Yes I can use cores. bdstone914 at bdstone914 at aol dot com Bruce The car is 120 miles away right now. I can get pics next weekend, or if you have pics of the two different ones, I can probably tell the difference. As far as I know, mine are original off a '72, if that helps. Are the two different variations interchangeable? The latches have two bumps on top that match to the part on the targa top. Wrong ones will fit but leave a top loose or sitting high. the C-C distance between the bumos is different. What year is the car? I think the change is in 1972. |
tbox56 |
Aug 29 2016, 09:13 PM
The latches have two bumps on top that match to the part on the targa top. Wrong ones will fit but leave a top loose or sitting high. the C-C distance between the bumos is different. What year is the car? I think the change is in 1972. The car is a '72. I guess i'll get pictures and measurements next weekend, i guess i won't be able to tell the difference. Thanks Bruce |
bdstone914 |
Aug 31 2016, 08:15 PM
note the size of the humps.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 28th March 2024 - 07:11 PM |
