Idle Speed Issue - 1975 1.8L |
telank |
Aug 29 2016, 10:00 AM
Newbie Group: Members Posts: 8 Joined: 23-August 15 From: Indiana Member No.: 19,091 Region Association: Upper MidWest |
I'm in need of ideas to resolve an idle speed dilemma. My 914 is a 1975 1.8L which I bought about a year ago. It seems to be very stock and still has the L Jetronic FI system in place. Here is the challenge.... I have been using the process in the Haynes manual for setting idle speed. If I set the speed when the car is warm, the next time t is started cold it is difficult to start and will idle so slow it barely stays running. Once warmed up all is good. If I set the idle speed right after starting before it is up to temperature - after it does warm up - it will be idling at over 2,000 RPM. Outside of this issue the car runs good and strong. The plugs are perfect color - so no indication of too lean or rich mixture. Thanks for your thoughts or ideas!
pete000 |
Aug 29 2016, 06:54 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
Like Dave said, the AAR is not working properly. Check to see if it is functioning. Also check to verify it is getting power when the car is running. I have an issue of mine not getting power causing the AAR not to work.
Yours sounds like it might be stuck closed or not getting power. Take it out and soak it in Kerosene for a few days, blow it out and hook it up to 12V and see if it opens. If it does check it in the car to see if it is getting power and opening. Lots of posts on how to do this. One more thing it to not have any vacuum leaks ! The L-Jet is very sensitive to any air leaks. Poor and erratic idle is almost always an air leak problem. |
Lo-Fi Version | Time is now: 19th May 2024 - 05:11 AM |
