Idle Speed Issue - 1975 1.8L |
telank |
Aug 29 2016, 10:00 AM
Newbie Group: Members Posts: 8 Joined: 23-August 15 From: Indiana Member No.: 19,091 Region Association: Upper MidWest |
I'm in need of ideas to resolve an idle speed dilemma. My 914 is a 1975 1.8L which I bought about a year ago. It seems to be very stock and still has the L Jetronic FI system in place. Here is the challenge.... I have been using the process in the Haynes manual for setting idle speed. If I set the speed when the car is warm, the next time t is started cold it is difficult to start and will idle so slow it barely stays running. Once warmed up all is good. If I set the idle speed right after starting before it is up to temperature - after it does warm up - it will be idling at over 2,000 RPM. Outside of this issue the car runs good and strong. The plugs are perfect color - so no indication of too lean or rich mixture. Thanks for your thoughts or ideas!
TheCabinetmaker |
Aug 31 2016, 01:44 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Dave, I've determined that the stock rotary aar does not supply enough air for my cammed 9:1 compression 2056. Looking for an alternative aar that would supply more air, or even be adjustable. It just won't idle cold. I can remove the hose from the aar outlet and make it idle properly by letting a little more air in.
Lo-Fi Version | Time is now: 28th May 2024 - 05:30 AM |
