Idle Speed Issue - 1975 1.8L |
telank |
Aug 29 2016, 10:00 AM
Newbie Group: Members Posts: 8 Joined: 23-August 15 From: Indiana Member No.: 19,091 Region Association: Upper MidWest |
I'm in need of ideas to resolve an idle speed dilemma. My 914 is a 1975 1.8L which I bought about a year ago. It seems to be very stock and still has the L Jetronic FI system in place. Here is the challenge.... I have been using the process in the Haynes manual for setting idle speed. If I set the speed when the car is warm, the next time t is started cold it is difficult to start and will idle so slow it barely stays running. Once warmed up all is good. If I set the idle speed right after starting before it is up to temperature - after it does warm up - it will be idling at over 2,000 RPM. Outside of this issue the car runs good and strong. The plugs are perfect color - so no indication of too lean or rich mixture. Thanks for your thoughts or ideas!
Dave_Darling |
Sep 1 2016, 03:27 PM
I bet you could cut the opening in the disc in the 1.8 valve to let more air through. You could probably drill the rotor in the 1.7/2.0 version, as well. You'd still be limited by the vacuum fittings and the bends through the piece, but you could likely get more than you have that way.
--DD |
Lo-Fi Version | Time is now: 19th May 2024 - 03:11 AM |
