Idle Speed Issue - 1975 1.8L |
telank |
Aug 29 2016, 10:00 AM
Newbie Group: Members Posts: 8 Joined: 23-August 15 From: Indiana Member No.: 19,091 Region Association: Upper MidWest |
I'm in need of ideas to resolve an idle speed dilemma. My 914 is a 1975 1.8L which I bought about a year ago. It seems to be very stock and still has the L Jetronic FI system in place. Here is the challenge.... I have been using the process in the Haynes manual for setting idle speed. If I set the speed when the car is warm, the next time t is started cold it is difficult to start and will idle so slow it barely stays running. Once warmed up all is good. If I set the idle speed right after starting before it is up to temperature - after it does warm up - it will be idling at over 2,000 RPM. Outside of this issue the car runs good and strong. The plugs are perfect color - so no indication of too lean or rich mixture. Thanks for your thoughts or ideas!
Porschef |
Sep 1 2016, 06:06 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Ok. I know I tested my AAR and it operated fine. Not sure if I checked the harness... (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/dry.gif)
Lo-Fi Version | Time is now: 19th May 2024 - 02:52 AM |
