Idle Speed Issue - 1975 1.8L |
telank |
Aug 29 2016, 10:00 AM
Newbie Group: Members Posts: 8 Joined: 23-August 15 From: Indiana Member No.: 19,091 Region Association: Upper MidWest |
I'm in need of ideas to resolve an idle speed dilemma. My 914 is a 1975 1.8L which I bought about a year ago. It seems to be very stock and still has the L Jetronic FI system in place. Here is the challenge.... I have been using the process in the Haynes manual for setting idle speed. If I set the speed when the car is warm, the next time t is started cold it is difficult to start and will idle so slow it barely stays running. Once warmed up all is good. If I set the idle speed right after starting before it is up to temperature - after it does warm up - it will be idling at over 2,000 RPM. Outside of this issue the car runs good and strong. The plugs are perfect color - so no indication of too lean or rich mixture. Thanks for your thoughts or ideas!
timothy_nd28 |
Sep 2 2016, 01:23 PM
You can't even run a Ljet without the oil fill cap screwed tightly. The AAV has descent sized vacuum lines, no way you can leave one of those off. This system is extremely sensitive to vacuum leaks. Something else is going on with his system where he has to introduce a huge vacuum leak in order to get his car to idle. (IMG:style_emoticons/default/bs.gif)
Lo-Fi Version | Time is now: 28th May 2024 - 02:54 AM |
