Idle Speed Issue - 1975 1.8L |
Sep 1 2016, 03:27 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I bet you could cut the opening in the disc in the 1.8 valve to let more air through. You could probably drill the rotor in the 1.7/2.0 version, as well. You'd still be limited by the vacuum fittings and the bends through the piece, but you could likely get more than you have that way.
--DD |
orthobiz |
Sep 1 2016, 03:57 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
I had a constantly searching idle on my 1974 1.8. Brad Mayeur fixed it with a "new" vacuum advance on the distributor. One side was not making a proper seal or something.
Good luck! Paul |
pete000 |
Sep 1 2016, 04:15 PM
I have a few AARs and noticed some of the heater elements are just pressed in and can rotate in the housing. I also have one that has a pin in it preventing it from spinning or pulling out.
orthobiz |
Sep 1 2016, 05:27 PM
Also, my car would idle OK when cold and then conked out when warmed up for only a couple of minutes. I had bad connections in the dual relay so I'd recommend cleaning the contacts to it, just to try it.
Paul |
Porschef |
Sep 1 2016, 05:44 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
TheCabinetmaker |
Sep 1 2016, 05:56 PM
Porschef |
Sep 1 2016, 06:06 PM
Ok. I know I tested my AAR and it operated fine. Not sure if I checked the harness... (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/dry.gif)
telank |
Sep 1 2016, 07:43 PM
Newbie Group: Members Posts: 8 Joined: 23-August 15 From: Indiana Member No.: 19,091 Region Association: Upper MidWest |
I have a few AARs and noticed some of the heater elements are just pressed in and can rotate in the housing. I also have one that has a pin in it preventing it from spinning or pulling out. Mine is the "pressed in" style without any locating pin. I have been working with it the last couple evenings and it acts as though it doesn't have enough force to reopen the valve when it cools. I can get it set so the valve is open when cold. It closes when it heats, but won't fully open again. Guessing I've no choice at this point but get a replacement? Any thoughts or ideas welcomed! Thanks! Tim |
timothy_nd28 |
Sep 2 2016, 07:44 AM
I think I'm being baited here. I'm unaware of any hoses on a Ljet system that you can disconnect and the engine would remain running
Sep 2 2016, 11:18 AM
You can disconnect some of the small ones. If things are adjusted very rich, you might even be able to run with one of the moderate-size ones disconnected.
--DD |
timothy_nd28 |
Sep 2 2016, 01:23 PM
You can't even run a Ljet without the oil fill cap screwed tightly. The AAV has descent sized vacuum lines, no way you can leave one of those off. This system is extremely sensitive to vacuum leaks. Something else is going on with his system where he has to introduce a huge vacuum leak in order to get his car to idle. (IMG:style_emoticons/default/bs.gif)
TheCabinetmaker |
Sep 2 2016, 04:03 PM
Lots of baiting going on these days Timothy.
Porschef |
Sep 2 2016, 06:08 PM
Yes, but there's been pretty much one Master here lately...
Gonna try to check voltage at the harness tomorrow, i imagine it should show 12v continuously. |
913B |
Sep 2 2016, 06:29 PM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
See my reply on post #19.
You can also see my all trials and errors by searching my name and keyword "idle" http://www.914world.com/bbs2/index.php?sho...p;#entry2314052 Good Luck |
Mark Henry |
Sep 2 2016, 06:30 PM
On the arr there's also a 90 degree rubber elbow to the 19mm hose. Often it feels tight, but as the engine warms up the rubber gets quite soft and will cause a leak. Same elbow is susceptible to small cracks that leak.
Lo-Fi Version | Time is now: 7th May 2024 - 08:36 AM |
