Oil: Cooling, flow rate and whats best? No answer; just thoughts. |
Cracker |
Aug 29 2016, 04:44 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
I've been thinking of this lately...
So when selecting an oil filter, there are variables such as flow rate, surface area of the filter itself and line size restrictions. So when using an external oil cooler, which in theory, would work most efficiently "holding" the oil for longer, extracting more energy in its exchange - does it make sense to use the "lowest" flow rated filter that conversely meets the maximum demand of the engine? This is relative with any engine that uses oil; and that oil gets hot - not an oil cooled/water cooled issue - neither are immune and both could benefit from the most efficient set up. Many "oil filters" claim hi-volume flow rate (28 gallons per minute!) - whats that good for if my max engine oil flow rate at WOT/Max temp is 6 GPM? The obvious opposing theory is that the longer oil is contained in an engine - the hotter it gets. So what would be the perfect formula for engine temp and oil quench? What say you? Tony |
Cracker |
Aug 29 2016, 07:59 PM
I'm specifically referring to max effort cars/engines. The GT3 RSR Cup uses dedicated water to oil heat exchangers to achieve ideal oil temps - even then, its a challenge. I obviously have the equivalent of nothing compared to Porsche so all my efforts need to achieved through trial and error. A stock scenario is easy peasy - racing, not so much.
Again, just on my mind...probably should have stayed there. (IMG:style_emoticons/default/rolleyes.gif) T |
Lo-Fi Version | Time is now: 7th May 2024 - 09:54 PM |
