Type 1 oil pump modifications for full flow, be sure to check this! |
crash914 |
Aug 29 2016, 06:39 PM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
Here are a couple of pictures showing what the differences are between a stock type 1 oil pump and a modified for type 4 use one.
This pump is also plugged for full flow. don't do this if you don't have a full flow take off cover. You will destroy your engine.. about 1/8 inch needs to be removed from the snout of the pump. Hopefully you can see that the pump won't seat as it hits the cam. Attached image(s) |
Mark Henry |
Aug 29 2016, 08:02 PM
You also have to use a type 1 pump made for a 3 rivet cam.
You still have to check for clearance pump body to the cam bolts. I don't use the washers that come with the cam, I use 620 locktite. |
Lo-Fi Version | Time is now: 16th May 2024 - 02:03 PM |
