Type 1 oil pump modifications for full flow, be sure to check this! |
crash914 |
Aug 29 2016, 06:39 PM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
Here are a couple of pictures showing what the differences are between a stock type 1 oil pump and a modified for type 4 use one.
This pump is also plugged for full flow. don't do this if you don't have a full flow take off cover. You will destroy your engine.. about 1/8 inch needs to be removed from the snout of the pump. Hopefully you can see that the pump won't seat as it hits the cam. Attached image(s) |
Mueller |
Aug 30 2016, 08:10 AM
What is the advantage of going full flow?
When or why or why not? |
Lo-Fi Version | Time is now: 16th May 2024 - 02:29 AM |
