Type 1 oil pump modifications for full flow, be sure to check this! |
crash914 |
Aug 29 2016, 06:39 PM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
Here are a couple of pictures showing what the differences are between a stock type 1 oil pump and a modified for type 4 use one.
This pump is also plugged for full flow. don't do this if you don't have a full flow take off cover. You will destroy your engine.. about 1/8 inch needs to be removed from the snout of the pump. Hopefully you can see that the pump won't seat as it hits the cam. Attached image(s) |
crash914 |
Aug 31 2016, 06:57 AM
I'm my case, I want to manage heat. Large remote filter, holds a quart, oil cooler, holds another quart and large lines to reduce the pressure drop. Larger lines and fewer sharp bands will reduce the pressure drop, which will result in less pump slip and more flow.
Lo-Fi Version | Time is now: 16th May 2024 - 02:01 AM |
