| 9fourteen14 |
Sep 5 2016, 08:26 PM
PORSCHE LUVA ![]() ![]() Group: Members Posts: 135 Joined: 5-July 15 From: boston Member No.: 18,920 Region Association: North East States |
where could I get some Silver Mettalic Z2V9?
I want to touch up a few areas on my teener. under the engine cover. I do have the add on that prevented water from getting in the engine bay.. I have removed that and Now I can see a few signs of paint peeling starting. my plan is to wire brush it and then clear coat it for now.... so it does not get any worse. on my 356 I have always used POR.. I know they have colors now and I know they have clear coat... but would love to have the original color. Z2V9.. any thoughts or comments or tips? 914 Luva |
| Cal |
Sep 5 2016, 09:07 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 618 Joined: 19-November 14 From: Philadelphia Member No.: 18,138 Region Association: North East States |
| 9fourteen14 |
Sep 7 2016, 09:15 AM
umm on my Porsche certificate of authencity is has Silver metallic Z2V9 something happened here! thanx for the chart anyone have any idea what Z2V9 is? no I am wondering if the real color was U2V9.. but there was a typo i see no trace of U2V9 on the automobile thanx anyway |
| rhodyguy |
Sep 7 2016, 09:41 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,254 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
The paint code on the jam tag is L96D for my silver 73'. Start with that code when you go paint shopping. Perhaps the z2v9 is just a superceeded number.
| JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,390 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
U2V9 is the factory code for a Creamsicle.
What is the code embossed into the drivers door front plate? |
| 914time |
Sep 7 2016, 12:41 PM
Member ![]() ![]() Group: Members Posts: 68 Joined: 7-August 14 From: St. Paul, Minnesota Member No.: 17,750 Region Association: Upper MidWest |
Does he have an LE?
| rhodyguy |
Sep 7 2016, 12:51 PM
My local auto paint store loaded spray cans for me when I did my engine compartment.
| iwanta914-6 |
Sep 7 2016, 12:58 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 718 Joined: 26-June 09 From: Minnesota Member No.: 10,510 Region Association: None
It appears that Z2V9 "Silver Metallic" is the color number, where as the color code is L96D
| 9fourteen14 |
Sep 8 2016, 03:21 PM
| Amphicar770 |
Sep 8 2016, 04:48 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,233 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region
These guys will mix up any color you need. I've used them and have been totally satisfied.
http://www.apstowerpaint.com Just be careful if you go with the 2k stuff. It is isocyanate based and you should be spraying it with a full face fresh air respirator. Just a mask is not sufficient. |
Lo-Fi Version | Time is now: 16th November 2026 - 04:03 PM |
