Anybody done this swap?, 1.8T + Transmission out of VW Passat |
cdmcse |
Apr 15 2005, 02:00 PM
Member Group: Members Posts: 340 Joined: 17-December 04 From: Georgetown, Ky Member No.: 3,305 |
The engine in a newer vw passat is a longitudinal mount with front wheel drive. The tranny is similar to a 901 setup. Anybody used this engine and tranny combo in a 914? Will it fit?
(IMG:http://i21.ebayimg.com/02/i/03/70/3d/f7_1_b.JPG) |
lapuwali |
Apr 15 2005, 02:05 PM
I'll bet that's the same or very similar to the Audi gearbox others have mentioned recently. Neo914 is doing a V6 swap out of an Audi, and I think he's using the gearbox, too.
andys |
Apr 15 2005, 02:17 PM
That's the model 012 Audi A4,6,8/Passat transaxle used from about '97 up. Depending on which code, it can have some very decent ratio's. I'll say again, that this 1.8T is an interesting swap, if it fits. Nice modern drivetrain, IMHO. Andy |
Mueller |
been done...twice
1st one is a tube frame car (pictures posted here somewhere) 2nd one is street car...just looked at it last week, no pictures, it started to rain.... amazingly, he was able to use 911 axles and they bolted right up to the audi gear box....he has not driven the car yet, working on the cable shifting for the gear box. |
Foxman |
Apr 15 2005, 02:38 PM
Member Group: Members Posts: 57 Joined: 17-March 05 From: Fort Worth, TX Member No.: 3,778 |
I can vouch for the reliability and tunability of the 1.8T engine from first-hand experience. I just sold a '01 Jetta 1.8T that had 350HP about a month ago and my wife's GTI has a 1.8T in it. If you can do the swap, I say go for it. I would be interested in doing this also in the future. Keep us posted if you do it.
andys |
Apr 15 2005, 02:39 PM
Mueller, I'd love to see some pic's of that installation if and when that's possible. 911 axles, huh; nice to know they bolt up. I recall (I'm stretching here) that the 012 transaxle output flanges are assymetric to the input shaft axis. Of course one could simply offset mount the whole motor/trans to compensate, so it's not a big deal. Did the street car have a front mounted radiator? Andy |
flyloki |
Apr 15 2005, 02:42 PM
Member Group: Members Posts: 138 Joined: 20-October 03 From: 8:00 in Boise, Idaho Member No.: 1,264 |
I'm planning on doing this swap or a TDI swap with same tranny. That's great to hear about the 911 axles, what year were they out of or does it make a difference?
As far as the cable shifter, I hope to use one from a Boxter. I've looked at the B4 Passat/Audi tranny and it looks identical to the Boxter 5 spd. Can anyone confirm this? |
Mueller |
Apr 15 2005, 02:54 PM
the audi/passat gearbox is basicly a tailshifter with a single rod that protrudes from the backside of the box, the shifting will be similar to a 915 or 930 gearbox the one Boxster transmission I've seen, is more of a sideshifter and would be a little easier to implement since you should be able to use the Boxster shifter and cables. |
75boxster |
Apr 15 2005, 03:06 PM
Member Group: Members Posts: 89 Joined: 1-January 04 From: Ft. Collins, CO Member No.: 1,488 |
SKS on Audiworld did the tube frame 914. He told me he bolted up the Boxster shifter
right up to the A6 tranny he was using. I believe the A4/Passat 012 is externally is very much the same. You will also have to figure out the hydraulic clutch the 012 operates with. Just some quick measurements: 012 - engine mount to center line of output flange 7.25" 012 - Total transmission length 24" 901 - engine mount to center line of output flange 8.00" 901 - Total transmission lenth 23" I have the two of these trannys sitting in the garage so if anyone need more measurements just say so (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Mueller |
Apr 15 2005, 03:18 PM
how is the 012 shifted??
is there a single rod in the back or 2 levers on the side? the early Boxsters have 2 levers on the side the Audi box in Sonus car has a single rod on the back of the transmission |
andys |
Apr 15 2005, 03:34 PM
75boxster,
Does the 012 have the clutch slave cylinder that has a plastic housing. If so, what type of coupling or hose atttaches to it? My 01E 6 speed has the plastic one, and short of buying an expensive factory hose assembly, I'd like some idea of what it is and where I can buy just the mating fitting. The 5 speed Boxster sure *looks* similar to the 012, and the listed ratios are identical to of some Audi/Passat. Flyloki, If you go with a TDI, try to locate a Euro version; it is commonly available with a six speed. Andy |
flyloki |
Apr 15 2005, 03:40 PM
Here's an ebay pic from a few weeks ago
It was titled 97-04 Boxter trans, I'm not sure if that was the Date of manufacture or just some other number. Attached image(s) |
flyloki |
Apr 15 2005, 03:51 PM
I assume the 6spd TDI came in euro Passat/A4/A6? Know what years in particular? I can't use Golf /Jetta /Bora /Beetle due to transverse layout.
Mueller |
Apr 15 2005, 04:07 PM
Boxster "S" transmission:
note two levers on the side of the transmission (IMG:http://forums.pelicanparts.com/uploads3/Boxster_Transmssion_7+2+2004_06_small1088861960.jpg) |
cdmcse |
Apr 15 2005, 04:36 PM
I think if I was going to do it I would just locate a complete engine and tranny Together from a passat or just get a whole wrecked car.. That seems to cheapest set-up.
Is there a particular year that is better to look for to get the best reliablility or gear ratios? |
cha914 |
Apr 15 2005, 04:42 PM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
ooo...got any more pics of that car? I guess I missed that thread.
Tony |
flyloki |
Apr 15 2005, 04:45 PM
The engine/trans combo set up would be preferable for myself as well; especially if I do the TDI swap. The lower revving TDI would do much better with correct ratios.
Otherwise you may want to consider the boxter trans if the cable shifter setup is bolt on. IIRC the Boxter 5spds were not very spendy and may (can anyone comment here) have LSD. |
andys |
Apr 15 2005, 04:50 PM
Correct, Euro TDI. My database is gone, but from memory, all the later 6 speed TDI models started somewhere around '96.......Stay with the later versions ('99+), as they introduced an upgraded stronger 1st gear that was otherwise prone to breakage. Some early versions of the 01E were 5 speeds. Andy |
75boxster |
Apr 15 2005, 07:26 PM
As far as VW/Audi 012's go, an early setup 97-99.5 would be my choice as the AEB motors are drive by cable
so wiring would be easier and the pre 99.5 012's are slightly cheaper to put a Quaife in. Tranny is plenty strong as I also had over 300hp in my Passat and never had a problem related to the hight HP. The AEB head also seems to possibly have more potential for HP with bigger ports. I remember the slave cylinder being plastic with a small section of steel pipe coming out of it and then transitioning to rubber hose. |
neo914-6 |
Apr 15 2005, 08:14 PM
search 1.8t 914 in the classifieds, Sonu is selling his current chassis because he just bought a car with a nicer body to transplant his Audi drivetrain. As I recall he did drive it behind his house... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) I like the 1.8t alot but would like to tread new waters and Neo914 is a concept car...If Jason was further along I'd go boxster but I didn't want the engine conversion to modify the rear suspension. That's why I got the track car. I have the boxster 5 speed with cable shift. I can't test fit them until after WCC05 since my garage is full with my V8 car and it's hot engine. The Audi parts are all over the place. My Neo914 chassis won't be back from Washington until early next month. I'll trial fit the drivetrain and fab the mounts then. Stay tuned... |
Lo-Fi Version | Time is now: 28th May 2024 - 05:31 AM |
