Left Rear 1/4 Panel New, Where to buy and how much |
roundboy914 |
Apr 15 2005, 02:39 PM
Member Group: Members Posts: 210 Joined: 16-October 03 From: Chicago, IL Member No.: 1,251 |
I need a new driver's side rear 1/4 panel. I got a price for a NOS one, and just about coughed up a kidney. I would like to know a little more about this item before pulling the trigger. Who has these for sale, and how much should they run?
TonyAKAVW |
Apr 15 2005, 02:50 PM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
I was in need of the same thing. I didn't need the entire panel because the section that was damaged was towards the back, but I still wanted to just replace the whole darn thing. There was an ad on the classifieds section here for a free set of fenders so I went and picked them up. Basically they were 1/4 chunks of a 914. After looking at how much metal removal I had to do I decided to just cut off the back part that I needed and live with having to weld two pieces together. Still it was a lot of metal removal work. Took a few hours of work with a reciprocating saw and later a plasma cutter and then a drill for the spot welds.
So if you don't want to spend a fortune on a NOS panel, you'll probably have to do what I did and remove them from a car or chunk of a car that has it intact. I figure you should be able to get the pieces for cheap, certainly orders of magnitude cheaper than NOS. -Tony |
Mueller |
Apr 15 2005, 02:59 PM
you might want to search for the thread about someone selling these on Pelican and on eBay...I "thought" he wanted $1200 each which seems about right for an NOS part like that.
Lo-Fi Version | Time is now: 6th May 2024 - 02:06 PM |
