Mallory Unilite Setup, Setting up grey springs for Mallory Unilite |
catsltd |
Sep 8 2016, 09:05 AM
Member Group: Members Posts: 181 Joined: 7-June 15 From: Calgary Alberta Member No.: 18,814 Region Association: None |
I have grey springs that I need to install in my Mallory Unilite distribitor.(Non Vacuum).
I am having problems figuring out How to install them,no instructions online,and no tool came with the springs. I also dont understand how to setup iniital advance on distributor. Sure could use some advice. Car has limited power above 3500 RPM,and does not start that great,so thinking Initial advance is not great??. Thanks Grant |
maf914 |
Sep 8 2016, 12:10 PM
catsltd |
Sep 8 2016, 02:59 PM
Thanks for the link. I already downloaded it,but it does not say how a person is supposed to remove or install a new set of springs. Was hoping for some help with that. Thanks Grant |
Mueller |
Sep 8 2016, 03:04 PM
Very carefully!
They just slide over the detent of the spring perch. A small jewelers screwdriver or pick might help. |
Lo-Fi Version | Time is now: 27th May 2024 - 06:39 PM |
