> Eastwood Internal Frame Coating, Anyone use it on the center tunnel?
Larry.Hubby
post Sep 10 2016, 09:20 PM
Member who doesn't post much, but has a long time in 914s
And if you did, what did you do to protect things like the shift bushings and the wiring harness?
Mike Bellis
post Sep 10 2016, 10:54 PM
Resident Electrician
The coating won't hurt the wiring, just cover it. You can remove the shifter, rod and bushings. My guess is your bushing should be replaced any way. Just keep it away from the throttle and clutch tube ends. You don't want it in there or on the cables.
jmitro
post Sep 11 2016, 08:11 AM
yes I've used it in many areas, but my car is a bare metal chassis. It works really well to snake into those areas I cannot reach with paint
Mr. Olympic Blue 2 You
post Sep 11 2016, 09:18 AM
I also used it on a bare chassis. If you have the engine out you can access some spots in the shift tunnel thru the engine bay that are hard to otherwise. I used Eastwoods rust converter first then followed up with the frame coating. It is very thin and does seem to get into all those nooks and crannies.
Andrew
rick 918-S
post Sep 11 2016, 12:04 PM
Hey nice rack! -Celette
I use it. Flows very well and stays fluid long enough to creep into pinch flanges and seams.
Harpo
post Sep 11 2016, 02:05 PM
Me too and I also recommending pulling everything out of the tunnel
euro911
post Sep 11 2016, 04:01 PM
(IMG:style_emoticons/default/agree.gif) with all of the above. I used it in the center tunnel while the drive train was out ... will eventually get around to the longs before new carpet goes in.
- Lo-Fi Version Time is now: 9th November 2026 - 11:41 PM
